used ADE for some time now. But suddenly, when I now start ADE it doesn't open, but tries to load the library files for hours. Even shutting it down with the task manager (operating system: Windows 10) doesn't change the situation. I already deinstalled and installed it again. But without success. Same issue again.
Any ideas?
THX!
I have exactly the same issue. I tried uninstalling and installing an earlier version but still freezes at opening the library
Have the same issue. Anyone have any idea how to fix this?
Exactly same issue. I thought it might be ADE edition in newer version so tried to do the uninstall of ADE 4.5.6 and reload with ADE 3.0. Won't allow it to load older version. Says it is already installed.
Have done all the troubleshooting ideas posted including full factory reset of device. It still works fine.
Issue seems to be with transfer of book to device so has to be adobe issue not device issue. Glitch in ADE programming.
I have been able to solve my problem with the endless loading of the library. I went in to My Digital Editions and opened the Manifest. This is located at C: /users/ my name/desktop /documents/my Digital Editions /manifest
I selected and deleted the files there. After that I was able to download ebooks from the library and they opened and transferred to my kobo reader successfully. Finally!
Tried that and had to keep going back to Manifest to delete copies [up to 15 on there!]. Then when I had one copy left I tried to drag and drop to my ereader. And again it just kept 'fulfilling content'. Sigh.....
I deleted all files in the manifest, uninstalled ade and then reinstalled. Took out a new book from the library and it worked. A lot of monkeying around for sure.
Sounds simple and straight forward and I don't doubt it works for you.
I visited my Library today and was told overdrive is the issue and they updated to a new app called LIBBY.
Tried that. Does not support a KOBO just a Kindle for now.
Have tried to de-authorize KOBO again. Now can't get my Kobo to show that it has ADE authorized.
Having the same problem, I tried out every suggestion shown here; re-installing, removing the contents from the manifest, doing that and re-installing, removing contents again etc. ADE keeps freezing.
The customer support algorithm keeps redirecting me to the forums without giving me another option to contact actual adobe support (email, phone, chat) 😕
Had the same problem on a new computer. Finally realized that my name was diffeernt on the new computer, and the files I copied from the old computer were in a different documents directory, where the My Digital Editions and all the previous files were hiding. Once I moved this entire subdirectory to users/<my new name>/Documents, ADE was happy to open. But it would not find any of the old files, probably since I was unable to "authorize" an epub source acceptable to Adobe. But new files work fine.
