I've added an audio mp3 file to my older version of Dreamweaver MX. Works great but it autoplays everytime the page loads and I need that to stop. I've read through the forum and have tried the fix of adding a code to the parameters (autoplay="false") but it still won't stop. Here's my code:
<embed src="sermons/Adam11.5.17Sermon.mp3" width="400" height="100" align="middle" autoplay="false"></embed>
I've also tried autostart="false" and that doesn't work.
Here's the site: CUCC Sermons
Do you have any other fixes or options I could try?
Thanks, Lori
You can fight with the archaic <embed> and <object> tags and the discrepancies between browsers with autostart and autoplay, or you can move to an HTML5 doctype and simply use the <audio> tag that modern browsers treat the same.
HTML5 <audio> doesn't auto-play by default. If you want it to autoplay, all you need to do is add the "autoplay" attribute to the <audio> tag in the same way "controls" is added below...
<audio style="width:400px; height:100px;" controls>
<source src="sermons/Adam11.5
...Copy link to clipboard
Please try to add the type properties to the embed file:
<embed
type="audio/mpeg"
And then add autoplay= false and autostart = false.
In that way also chrome could honorate the autoplay/autostart = false
I don't recommend using audio <embed>.
Jon's answer is the correct one. Use the HTML5 <audio> tag.
<source src="sermons/Adam11.5.17Sermon.mp3" type="audio/mp3" />
</audio>
You are also missing a doctype declaration on your page. Before the opening <html> tag, add in the following as the first line of your code...
<!doctype html>
<html>
Thank you Jon - that worked great! One issue though - I can't seem to move the audio player to where I want it to be on the page. I want it to be under the date November 5, 2017, but it keeps showing up way above the heading Sermons. Here is the website and code CUCC Sermons .Thanks so much!!!
<p align="left"><strong><font color="#000000">God Loves the Canaanites, Too</font></strong><font color="#000000"><br>
<font size="2">Rev. Adam Ericksen<br>
November 5, 2017</font></font></p>
<hr>
<p align="left"> <tr> <audio style="width:400px; height:100px;" controls> <source src="sermons/Adam11.5.17Sermon.mp3" type="audio/mp3" />
</audio>
</p>
well the snippet that you just copy paste here, doesn't correspond to the one published on line
here are some comment on this video
Check your page against the validator at http://validator.w3.org/nu and clean up the errors dealing with extra and out of position <p>, <tr> and <td> tags.
It looks to me like you may have an errant copy/paste causing some issues there.
Thanks Jon - I don't have much experience with html, but I'll try this and see what I can figure out. I really appreciate your help! I'll let you know how it worked.
