Hi All,
I was trying to do A/B test on billing page and tried visual experience builder to update text but i am not seeing content in VEC i see error (screenshot below). but when i use the url in browser i can see the content. Anyone has idea why its happening?
In VEC:
Saila
Solved! Go to Solution.
Hi Saila,
It's possible that your server doesn't allow unknown query parameters to be added into the URL. Our VEC adds a couple of query parameters to the page when loading to help prevent Target from loading any test content that could be live in another activity. You can verify this by trying to load your billing page in a separate tag with these parameters added to the URL: &mboxEdit=1&mboxDisable=1. Be sure to add them after a "?". If the page loads fine with those parameters added then something else is going on. If you get the same "Whoops! ..." page that means your server doesn't allow those parameters that Target's VEC needs. In this case you can try 2 things:
Hi Saila,
