Hello,
Updated to 19.0, I am no longer able to drag a marquee (without selection) using the rectangular marquee tool. All other marquee tools work.
When I draw a selection with this tool, rather than getting a small white arrow and square drawn with a dotted line (which allows me to drag the marquee), I get instead a vertical and horizontal cross hair (the marquee tool before you draw with it) and a little 'x' - meaning if I click I just get rid of the marquee.
If I change to another marquee tool, I can then drag the square/rectangle marquee but not without this workaround step.
I have tried resetting the tools
I have tried starting Photoshop holding down the buttons to rest preferences
Neither worked.
OS Sierra 10.12.6
iMAc Reina 5k / 4Ghz Intel Core i7
Any ideas? Thanks
Change the options from this (Intersect with selection)
to this (New Selection) :
Dave
Dave
I had the same problem. I did change the options. The marquee did add new but when I went to move the new section the entire subject moved behind. So new to all this.
thank you today is 12 17 2022 and I followed your suggestion and it worked ---thanks
Thanks for the speedy and correct reply. Really appreciated.
Anthony
You're welcome
Dave
