Smart Object Automation Script
Mar 07, 2017 Mar 07, 2017
I'm currently trying to make a couple of tweaks to this script, (the script currently grabs a number of files from a folder and replaces the content of a smart object and saves individual jpgs):
#target photoshop
if (app.documents.length > 0) {
var myDocument = app.activeDocument;
var theName= myDocument.name.match(/(.*)\.[^\.]+$/)[1];
var thePath = myDocument.path;
var theLayer = myDocument.activeLayer;
// jpg options;
var jpgopts = new JPEGSaveOptions();
jpgopts.embedProfile = true;
jpgopts.formatOptions = FormatOptions.STANDARDBASELINE;
jpgopts.matte = MatteType.NONE;
jpgopts.quality = 8;
// check if layer is smart object;
if (theLayer.kind != "LayerKind.SMARTOBJECT") {alert ("selected layer is not a smart object")}
else {
// select files;
if ($.os.search(/windows/i) != -1) {var theFiles = File.openDialog ("please select files", "*.psd;*.tif;*.jpg", true)}
else {var theFiles = File.openDialog ("please select files", getFiles, true)};
if (theFiles) {
// work through the array;
          for (var m = 0; m < theFiles.length; m++) {
// replace smart object;
                    theLayer = replaceContents (theFiles, theLayer);
                    var theNewName = theFiles.name.match(/(.*)\.[^\.]+$/)[1];
//save jpg;
                    myDocument.saveAs((new File(thePath+"/"+theName+"_"+theNewName+".jpg")),jpgopts,true);
////// get psds, tifs and jpgs from files //////
function getFiles (theFile) {
     if (theFile.name.match(/\.(psd|tif|png)$/i) != null || theFile.constructor.name == "Folder") {
          return true
////// replace contents //////
function replaceContents (newFile, theSO) {
app.activeDocument.activeLayer = theSO;
var idplacedLayerReplaceContents = stringIDToTypeID( "placedLayerReplaceContents" );
    var desc3 = new ActionDescriptor();
    var idnull = charIDToTypeID( "null" );
    desc3.putPath( idnull, new File( newFile ) );
    var idPgNm = charIDToTypeID( "PgNm" );
    desc3.putInteger( idPgNm, 1 );
executeAction( idplacedLayerReplaceContents, desc3, DialogModes.NO );
return app.activeDocument.activeLayer
I need to change the script to select a folder of images, rather than specific files using this:
var theFolder = Folder.selectDialog ("select folder");
if (theFolder) {
var theFiles = theFolder.getFiles(/\.(jpg|tif|eps|psd)$/i)
However my lack of JS experience is showing and i can't figure out where to insert the new lines of code.
It would also be ideal if I could incorporate a way to open up a dialogue which would allow me to select a destination folder for the saved files.
Hope this makes sense!
Thanks in advance,
Rik
Actions and scripting
3.3K
Advocate , Mar 09, 2017 Mar 09, 2017
Took a liberty to add previous lines to code. Check if it works.
#target photoshop
    var theName = myDocument.name.match(/(.*)\.[^\.]+$/)[1];
    // jpg options;
Adobe
Mar 08, 2017 Mar 08, 2017
A quick look at that script I see If  there is a document open the script checks to see if the targeted layer is a smart object and if  it is will prompt you with a file selection dialog to select files.
You would replace that dialog with a select folder dialog then process the image file types in that folder.  They should all be exactly the same size and resolution as the original smart object so that the smart object layer's associated transform will transform the image correctly for the layers transform is not replaced.
JJMack
Thanks JJMack! I figured out how to get the script to load a folder in. But when it comes to setting a save destination i'm still at a bit of a loss.
Rik
Advocate ,
Hei Rik.
One way for you to select destination folder is to call SelectDialog method
var destinationFolder = Folder.selectDialog("Please select a destination folder");
then once you have that, you can pass this to your saveAs function
myDocument.saveAs(new File(destinationFolder + "/" + theName + "_" + theNewName + ".jpg"), jpgopts, true);
Advocate ,
#target photoshop
    // jpg options;
        alert("selected layer is not a smart object")
    } else {
        // select files;
        var theFolder = Folder.selectDialog("select folder");
        if (theFolder) {
            var theFiles = theFolder.getFiles(/\.(jpg|tif|eps|psd|png)$/i);
            // Select destination folder
                theLayer = replaceContents(theFiles, theLayer);
                //save jpg;
                myDocument.saveAs((new File(destinationFolder.toString() + "/" + theName + "_" + theNewName + ".jpg")), jpgopts, true);
function replaceContents(newFile, theSO) {
    var idplacedLayerReplaceContents = stringIDToTypeID("placedLayerReplaceContents");
    var idnull = charIDToTypeID("null");
    desc3.putPath(idnull, new File(newFile));
    var idPgNm = charIDToTypeID("PgNm");
    desc3.putInteger(idPgNm, 1);
    executeAction(idplacedLayerReplaceContents, desc3, DialogModes.NO);
Mar 10, 2017 Mar 10, 2017
Thanks so much Tomas!
I got about half way there, but was still struggling with getting the dialogue to communicate with the save part ( lots to learn ).
Really, really appreciate the help!!
Guest
Mar 16, 2017 Mar 16, 2017
Hey guys,
thanks for your input! This script comes in well handy!
I do have an issue though. I changed the script to save .PSD's instead of .JPG's in order to keep the "smart object layer" intact.
But now the new PSD's smart object has been transformed into a locked background layer, prohibiting me from editing said smart object.
Is there anything I can add to the "psd options" to stop this from happening?
Advocate ,
Dec 29, 2020 Dec 29, 2020
@Deleted User
its been a while but you need to add a bool for that. see below. You said you changed it to PSD. So im not sure how you named the first part. Thats needs to be the same as the rest of your edit.
psdopts.layers = true;
Nov 08, 2017 Nov 08, 2017
Just wondering if there is a way to save the jpg as a percentage value. So I can input 50% as the value for quality
Advocate ,
for value you can enter 6 which is equivalent to 50%.
Nov 09, 2017 Nov 09, 2017
Hi
Thanks for the reply. Just wondering if there is any way to put it in as a percentage?
