Is there any way to delete rejected photos. I had some that were deleted for technical reasons that I fixed and resubmitted and were accepted. I'd like to get them out of the rejected group.
Jim McNees
You can't delete rejected photos! Not until adobe gives that option anyway.
I can't find a way to delete rejected photos using Safari on a desktop computer.
Actually you can, but it is not straight forward.
I have a parent folder called Photos. In Bridge, I select "Photos", then select View Sub-folders.
Now, on the right side of Bridge, click on the Filter tab, then select Ratings
You should see Rejected as a rating. Click on only Rejected. Now you should only see all of your rejected items from all sub-folders.
Select all of the files, and then delete them.
