When scaling a bitmap image on a html canvas it looks and works fine within Animate itself, as soon as it's played within a browser the motion between the two keyframes is incredibly jittery/shaky. I have had this issue with several projects i've worked on and still haven't managed to find a solid solution - Classic tweens seem to do it less, but once I add an ease they revert back to their 'jittery' ways. This only happens when scaling; key framing the position, rotation or anything else seems to work fine.
Any help would be greatly appreciated.
Chris
Can you post an example for us to try?
A classic tween with a preset, or a classic ease with an intensity of -100 to +100, should perform equally well. If you somehow have made a change to the graph then it becomes as bad as a motion tween. You can look at the JS file to see if anything went wrong, that made it publish as a custom ease even if you didn't mean to. Here's a bounce test I did, and the JS I got:
this.timeline.addTween(cjs.Tween.get(this.instance).to({scaleX:0.24,scaleY:0.24},80,cjs.Ea
...Copy link to clipboard
Can you try doing this on the latest release of Animate(2018), using the new ease presets for Classic tween.
It should give you much better results.
I'm currently using Animate 2018 but I appreciate the suggestion!
He's saying don't use custom eases.
Custom eases don’t help but it still does it without any kind of ease at all Sometimes, but only when scaling. There has to be a reason why...
this.timeline.addTween(cjs.Tween.get(this.instance).to({scaleX:0.24,scaleY:0.24},80,cjs.Ease.bounceOut).wait(1));
Here is the same bounce only I moved the graph a little, and back to being exactly the same tween, you can see why it affects the performance:
this.timeline.addTween(cjs.Tween.get(this.instance).wait(1).to({regX:216.6,regY:199.4,scaleX:0.99,scaleY:0.99,x:216.6,y:199.5},0).wait(1).to({scaleX:0.98,scaleY:0.98,x:216,y:199.1},0).wait(1).to({scaleX:0.97,scaleY:0.97,x:215.3,y:198.6},0).wait(1).to({scaleX:0.96,scaleY:0.96,x:214.5,y:198},0).wait(1).to({scaleX:0.95,scaleY:0.95,x:213.6,y:197.4},0).wait(1).to({scaleX:0.93,scaleY:0.93,x:212.7,y:196.7},0).wait(1).to({scaleX:0.92,scaleY:0.92,x:211.7,y:196},0).wait(1).to({scaleX:0.9,scaleY:0.9,x:210.7,y:195.2},0).wait(1).to({scaleX:0.88,scaleY:0.88,x:209.5,y:194.4},0).wait(1).to({scaleX:0.86,scaleY:0.86,x:208.4,y:193.5},0).wait(1).to({scaleX:0.84,scaleY:0.84,x:207.1,y:192.6},0).wait(1).to({scaleX:0.82,scaleY:0.82,x:205.8,y:191.7},0).wait(1).to({scaleX:0.8,scaleY:0.8,x:204.4,y:190.7},0).wait(1).to({scaleX:0.78,scaleY:0.78,x:202.9,y:189.6},0).wait(1).to({scaleX:0.75,scaleY:0.75,x:201.4,y:188.5},0).wait(1).to({scaleX:0.73,scaleY:0.73,x:199.7,y:187.3},0).wait(1).to({scaleX:0.7,scaleY:0.7,x:198,y:186},0).wait(1).to({scaleX:0.67,scaleY:0.67,x:196.2,y:184.7},0).wait(1).to({scaleX:0.64,scaleY:0.64,x:194.4,y:183.4},0).wait(1).to({scaleX:0.61,scaleY:0.61,x:192.4,y:181.9},0).wait(1).to({scaleX:0.58,scaleY:0.58,x:190.3,y:180.4},0).wait(1).to({scaleX:0.54,scaleY:0.54,x:188.2,y:178.9},0).wait(1).to({scaleX:0.51,scaleY:0.51,x:185.9,y:177.2},0).wait(1).to({scaleX:0.47,scaleY:0.47,x:183.5,y:175.5},0).wait(1).to({scaleX:0.43,scaleY:0.43,x:181,y:173.6},0).wait(1).to({scaleX:0.39,scaleY:0.39,x:178.3,y:171.7},0).wait(1).to({scaleX:0.34,scaleY:0.34,x:175.6,y:169.7},0).wait(1).to({scaleX:0.3,scaleY:0.3,x:172.6,y:167.6},0).wait(1).to({scaleX:0.25,scaleY:0.25,x:169.6,y:165.3},0).wait(1).to({scaleX:0.27,scaleY:0.27,x:170.8,y:166.2},0).wait(1).to({scaleX:0.3,scaleY:0.3,x:172.6,y:167.6},0).wait(1).to({scaleX:0.33,scaleY:0.33,x:174.5,y:168.9},0).wait(1).to({scaleX:0.36,scaleY:0.36,x:176.5,y:170.4},0).wait(1).to({scaleX:0.39,scaleY:0.39,x:178.6,y:171.9},0).wait(1).to({scaleX:0.42,scaleY:0.42,x:180.7,y:173.4},0).wait(1).to({scaleX:0.46,scaleY:0.46,x:182.8,y:175},0).wait(1).to({scaleX:0.49,scaleY:0.49,x:184.8,y:176.4},0).wait(1).to({scaleX:0.52,scaleY:0.52,x:186.6,y:177.7},0).wait(1).to({scaleX:0.54,scaleY:0.54,x:188.2,y:178.9},0).wait(1).to({scaleX:0.56,scaleY:0.56,x:189.4,y:179.7},0).wait(1).to({scaleX:0.57,scaleY:0.57,x:190.2,y:180.3},0).wait(1).to({scaleX:0.58,scaleY:0.58,x:190.7,y:180.7},0).wait(1).to({scaleX:0.58,scaleY:0.58,x:190.8,y:180.8},0).wait(1).to({scaleX:0.58,scaleY:0.58,x:190.6,y:180.6},0).wait(1).to({scaleX:0.57,scaleY:0.57,x:190.1,y:180.2},0).wait(1).to({scaleX:0.56,scaleY:0.56,x:189.3,y:179.7},0).wait(1).to({scaleX:0.54,scaleY:0.54,x:188.3,y:179},0).wait(1).to({scaleX:0.53,scaleY:0.53,x:187.2,y:178.1},0).wait(1).to({scaleX:0.51,scaleY:0.51,x:185.8,y:177.2},0).wait(1).to({scaleX:0.48,scaleY:0.48,x:184.4,y:176.1},0).wait(1).to({scaleX:0.46,scaleY:0.46,x:182.8,y:175},0).wait(1).to({scaleX:0.43,scaleY:0.43,x:181.1,y:173.7},0).wait(1).to({scaleX:0.4,scaleY:0.4,x:179.4,y:172.5},0).wait(1).to({scaleX:0.37,scaleY:0.37,x:177.6,y:171.1},0).wait(1).to({scaleX:0.34,scaleY:0.34,x:175.7,y:169.8},0).wait(1).to({scaleX:0.31,scaleY:0.31,x:173.7,y:168.3},0).wait(1).to({scaleX:0.28,scaleY:0.28,x:171.7,y:166.9},0).wait(1).to({scaleX:0.25,scaleY:0.25,x:169.7,y:165.4},0).wait(1).to({scaleX:0.25,scaleY:0.25,x:170,y:165.6},0).wait(1).to({scaleX:0.27,scaleY:0.27,x:170.9,y:166.3},0).wait(1).to({scaleX:0.28,scaleY:0.28,x:171.9,y:167},0).wait(1).to({scaleX:0.3,scaleY:0.3,x:172.7,y:167.6},0).wait(1).to({scaleX:0.31,scaleY:0.31,x:173.3,y:168},0).wait(1).to({scaleX:0.31,scaleY:0.31,x:173.7,y:168.3},0).wait(1).to({scaleX:0.31,scaleY:0.31,y:168.4},0).wait(1).to({scaleX:0.31,scaleY:0.31,x:173.5,y:168.2},0).wait(1).to({scaleX:0.3,scaleY:0.3,x:173.1,y:167.9},0).wait(1).to({scaleX:0.3,scaleY:0.3,x:172.6,y:167.5},0).wait(1).to({scaleX:0.28,scaleY:0.28,x:172,y:167.1},0).wait(1).to({scaleX:0.27,scaleY:0.27,x:171.3,y:166.6},0).wait(1).to({scaleX:0.26,scaleY:0.26,x:170.6,y:166},0).wait(1).to({scaleX:0.25,scaleY:0.25,x:169.8,y:165.5},0).wait(1).to({scaleX:0.24,scaleY:0.24,x:169.4,y:165.2},0).wait(1).to({scaleX:0.25,scaleY:0.25,x:169.9,y:165.6},0).wait(1).to({scaleX:0.26,scaleY:0.26,x:170.3,y:165.9},0).wait(1).to({scaleX:0.26,scaleY:0.26,x:170.5,y:166},0).wait(1).to({scaleX:0.26,scaleY:0.26,x:170.4,y:165.9},0).wait(1).to({scaleX:0.25,scaleY:0.25,x:170,y:165.7},0).wait(1).to({scaleX:0.25,scaleY:0.25,x:169.7,y:165.4},0).wait(1).to({regX:153.5,regY:153.5,scaleX:0.24,scaleY:0.24,x:154,y:154},0).wait(1));
