Line with straight base
Nov 10, 2017 Nov 10, 2017
Hello there, I've done some works in illustrator, but never create something from scratch.
I need to create a line like the image below but I don't know how. can someone help me with this?
227
Community Expert , Nov 10, 2017 Nov 10, 2017
If it is the shape that you are after and it does not need to be a stroke, you can use a rectangle and use the Shear Tool (found below the Scale Tool).
Adobe
Marco,
You may make the line longer than needed and then:
A) Object>Path>Outline Stroke, then create a rectangle with a top and bottom that corresponds to the desired cutoffs (or just two vertical lines there), then Object>Path>Divide Objects Below (for each separate line), then just delete the unwanted top and bottom to have the desired shape;
Or:
B) Object>Path>Outline Stroke, then create a rectangle with a top and bottom that corresponds to the desired cutoffs, then select everything and Pathfinder>Intersect;
Or:
C) Just keep the line with a stroke (or outline it) then create a rectangle with a top and bottom that corresponds to the desired cutoffs, then select everything and Ctrl/Cmd+7 to create a Clipping Mask.
C) is reversible, and you may Direct Select the line and move it about.
In any case, you can also start with the rectangle, then make the line.
Thank you for yur help
I've tried both and worked fine.
Thank You
Nov 11, 2017 Nov 11, 2017
For my part you are welcome, Marco.
Good to hear that it worked for you.
