2018 select and mask
Nov 11, 2017 Nov 11, 2017
Everyone says how the 2018 select and mask has been improved. Well for me it is impossible to use! I have a decent desktop computer which is pretty fast. I never have any issues with it normally. However when I try and use select and mask, it buffers for ages, like 5 minutes, and when it does work it does a dreadful job. Does anybody have any ideas as to what the problem could be?
641
Community Expert , Nov 11, 2017 Nov 11, 2017
Hi Tony
Try a couple of things :
1. Go to Preferences >Performance >Graphics Processor > Advanced and uncheck Open CL.  There are some who have had issues both with speed and with quality that are improved after unchecking that option.
You will need to start/open a new document to see the changes.
2. If that does not change go to Preferences > General >Reset Preferences on Quit. Then click OK and close and restart Photoshop.
Dave
Adobe
hi,
is this a photoshop question?
Sorry, yes it is. Everything else works fine, just select and mask that is unusable
Hi Tony
Dave
Thanks Dave, I'll try that later and let you know the outcome
Nov 13, 2017 Nov 13, 2017
Sorry couldn't do this as 'Open CL' was already unchecked. reset preferences and restarted PS but nothing has changed
It's absolutely unusable! It just freezes. The cursor can move around but it doesn't do anything after about 20 seconds of working on an image
I changed the 'Drawing Mode' from 'Advanced' to 'Normal' and that worked better, but far from perfect!
Hi
Can you go to Photoshop > Help > System info. Then click Copy and Paste the info here
Dave
Adobe Photoshop Version: 19.0 20170929.r.165 2017/09/29: 1138933  x64
Number of Launches: 4
Operating System: Windows 10 64-bit
Version: 10 or greater 10.0.16299.15
System architecture: Intel CPU Family:6, Model:12, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
Physical processor count: 4
Logical processor count: 8
Processor speed: 3598 MHz
Built-in memory: 16319 MB
Free memory: 7434 MB
Memory available to Photoshop: 14392 MB
Memory used by Photoshop: 70 %
Surface Dial: Enabled.
Alias Layers: Disabled.
Modifier Palette: Enabled.
Highbeam: Enabled.
Image tile size: 1024K
Image cache levels: 4
Font Preview: Medium
TextComposer: Latin
Display: 1
Display Bounds: top=0, left=0, bottom=1080, right=1920
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Normal
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumNativeGPUs=0
glgpu[0].GLVersion="4.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=2048
glgpu[0].GLName="NVIDIA GeForce GT 610"
glgpu[0].GLVendor="NVIDIA Corporation"
glgpu[0].GLVendorID=4318
glgpu[0].GLDriverVersion="22.21.13.8569"
glgpu[0].GLRectTextureSize=16384
glgpu[0].GLRenderer="GeForce GT 610/PCIe/SSE2"
glgpu[0].GLRendererID=4170
glgpu[0].HasGLNPOTSupport=1
glgpu[0].GLDriver="C:\WINDOWS\System32\DriverStore\FileRepository\nv_ref_pubwu.inf_amd64_841d56cc807f1f4d\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_ref_pubwu.inf_amd64_841d56cc807f1f4d\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_ref_pubwu.inf_amd64_841d56cc807f1f4d\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_ref_pubwu.inf_amd64_841d56cc807f1f4d\nvldumdx.dll"
glgpu[0].GLDriverDate="20170916000000.000000-000"
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.50 NVIDIA"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[65536]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
License Type: Subscription
Serial number: 96040317184743140047
GUIDBucket:
Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\
Temporary file path: C:\Users\Tony\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
  Startup, 1,81T, 1,70T free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\Plug-Ins\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Plug-Ins\
Installed components:
   A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
   ACE.dll   ACE 2017/09/19-18:51:44   79.586793   79.586793
   AdbePM.dll   PatchMatch 2016/11/03:19:48:57   1.578146   1.578146
   AdobeLinguistic.dll   Adobe Linguisitc Library   10.0.0
   AdobeOwl.dll   Adobe Owl   5.2.11
   AdobePDFL.dll   PDFL 2017/09/01-01:08:01   79.239219   79.239219
   AdobePIP.dll   Adobe Product Improvement Program   7.4.1.60.45263
   AdobeSVGAGM.dll   AdobeSVGAGM   79.586793   79.586793
   AdobeXMP.dll   Adobe XMP Core 2017/07/13-01:06:39   79.160924   79.160924
   AdobeXMPFiles.dll   Adobe XMP Files 2017/07/13-01:06:39   79.160924   79.160924
   AdobeXMPScript.dll   Adobe XMP Script 2017/07/13-01:06:39   79.160924   79.160924
   adobe_caps.dll   Adobe CAPS   10,0,0,6
   AGM.dll   AGM 2017/09/19-18:51:44   79.586793   79.586793
   ahclient.dll    AdobeHelp Dynamic Link Library   3.0.0.6
   AIDE.dll   AIDE 2016/05/27-01:08:49   79.574279   79.574279
   amtlib.dll   AMTLib (64 Bit)   10.0.0.221 BuildVersion: 10.0; BuildDate: Tue Aug 1 2017 8:28:8)   1.000000
   ARE.dll   ARE 2017/09/19-18:51:44   79.586793   79.586793
   AXE8SharedExpat.dll   AXE8SharedExpat 2015/03/13-23:40:54   79.562390   79.562390
   AXEDOMCore.dll   AXEDOMCore 2015/03/13-23:40:54   79.562390   79.562390
   Bib.dll   BIB 2017/09/19-18:51:44   79.586793   79.586793
   BIBUtils.dll   BIBUtils 2017/09/19-18:51:44   79.586793   79.586793
   boost_date_time.dll   photoshopdva   11.1.0
   boost_filesystem.dll   photoshopdva   11.1.0
   boost_signals.dll   photoshopdva   11.1.0
   boost_system.dll   photoshopdva   11.1.0
   boost_threads.dll   photoshopdva   11.1.0
   cg.dll   NVIDIA Cg Runtime   3.0.00007
   cgGL.dll   NVIDIA Cg Runtime   3.0.00007
   CITThreading.dll   Adobe CITThreading   2.1.0.1   2.1.0.1
   CoolType.dll   CoolType 2017/09/19-18:51:44   79.586793   79.586793
   CRClient.dll   Adobe Crash Reporter Client DLL   1.6.1.0
   dnssd.dll   Bonjour   3,0,0,2
   dvaaudiodevice.dll   photoshopdva   11.1.0
   dvacore.dll   photoshopdva   11.1.0
   dvacrashhandler.dll   Adobe Audition CC 2017   10.0.0
   dvamarshal.dll   photoshopdva   11.1.0
   dvamediatypes.dll   photoshopdva   11.1.0
   dvametadata.dll   photoshopdva   11.1.0
   dvametadataapi.dll   photoshopdva   11.1.0
   dvametadataui.dll   photoshopdva   11.1.0
   dvaplayer.dll   photoshopdva   11.1.0
   dvatransport.dll   photoshopdva   11.1.0
   dvaui.dll   photoshopdva   11.1.0
   dvaunittesting.dll   photoshopdva   11.1.0
   dynamiclink.dll   photoshopdva   11.1.0
   ExtendScript.dll   ExtendScript 2017/08/31-12:13:14   81.1133690   81.1133690
   icucnv40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
   icudt40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
   icuuc40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
   igestep30.dll   IGES Reader   9.3.0.113
   imslib.dll   IMSLib DLL   10.0.0.22
   JP2KLib.dll   JP2KLib 2017/08/23-01:11:25   79.267771   79.267771
   libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
   libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
   libmmd.dll   Intel(R) C/C++/Fortran Compiler   17.0.0
   LogSession.dll   LogSession   7.4.1.60.45263
   mediacoreif.dll   photoshopdva   11.1.0
   MPS.dll   MPS 2017/09/01-01:08:01   79.586120   79.586120
   pdfsettings.dll   Adobe PDFSettings   1.04
   Photoshop.dll   Adobe Photoshop CC 2018   19.0
   Plugin.dll   Adobe Photoshop CC 2018   19.0
   PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   8.0.0
   PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   8.0.0.55
   PSArt.dll   Adobe Photoshop CC 2018   19.0
   PSCloud.dll                                                   1.0.0.1
   PSViews.dll   Adobe Photoshop CC 2018   19.0
   SCCore.dll   ScCore 2017/08/31-12:13:14   81.1133690   81.1133690
   SVGRE.dll   SVGRE   79.586793   79.586793
   svml_dispmd.dll   Intel(R) C/C++/Fortran Compiler   17.0.0
   tbb.dll   Intel(R) Threading Building Blocks for Windows   2017, 0, 2017, 0118
   tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   2017, 0, 2017, 0118
   TfFontMgr.dll   FontMgr   9.3.0.113
   TfKernel.dll   Kernel   9.3.0.113
   TFKGEOM.dll   Kernel Geom   9.3.0.113
   TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
   updaternotifications.dll   Adobe Updater Notifications Library   10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   10.0.0.1
   VulcanControl.dll   Vulcan Application Control Library   5.3.0.16
   VulcanMessage5.dll   Vulcan Message Library   5.3.0.16
   WRServices.dll   WRServices Thu Jan 07 2016 04:50:10   Build 0.21960   0.21960
   wu3d.dll   U3D Writer   9.3.0.113
Required plug-ins:
   3D Studio 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
   Accented Edges 19.0 - from the file “Filter Gallery.8bf”
   Adaptive Wide Angle 19.0 - from the file “Adaptive Wide Angle.8bf”
   Angled Strokes 19.0 - from the file “Filter Gallery.8bf”
   Average 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Average.8bf”
   Bas Relief 19.0 - from the file “Filter Gallery.8bf”
   BMP 19.0 - from the file “Standard MultiPlugin.8bf”
   Camera Raw 10.0 - from the file “Camera Raw.8bi”
   Camera Raw Filter 10.0 - from the file “Camera Raw.8bi”
   Chalk && Charcoal 19.0 - from the file “Filter Gallery.8bf”
   Chrome 19.0 - from the file “Filter Gallery.8bf”
   Cineon 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Cineon.8bi”
   Clouds 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Clouds.8bf”
   Collada 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
   Color Halftone 19.0 - from the file “Standard MultiPlugin.8bf”
   Colored Pencil 19.0 - from the file “Filter Gallery.8bf”
   CompuServe GIF 19.0 - from the file “Standard MultiPlugin.8bf”
   Conté Crayon 19.0 - from the file “Filter Gallery.8bf”
   Craquelure 19.0 - from the file “Filter Gallery.8bf”
   Crop and Straighten Photos 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “CropPhotosAuto.8li”
   Crop and Straighten Photos Filter 19.0 - from the file “Standard MultiPlugin.8bf”
   Crosshatch 19.0 - from the file “Filter Gallery.8bf”
   Crystallize 19.0 - from the file “Standard MultiPlugin.8bf”
   Cutout 19.0 - from the file “Filter Gallery.8bf”
   Dark Strokes 19.0 - from the file “Filter Gallery.8bf”
   De-Interlace 19.0 - from the file “Standard MultiPlugin.8bf”
   Dicom 19.0 - from the file “Dicom.8bi”
   Difference Clouds 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Clouds.8bf”
   Diffuse Glow 19.0 - from the file “Filter Gallery.8bf”
   Displace 19.0 - from the file “Standard MultiPlugin.8bf”
   Dry Brush 19.0 - from the file “Filter Gallery.8bf”
   Eazel Acquire 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “EazelAcquire.8ba”
   Entropy 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
   Export Color Lookup Tables 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Export3DLUT.8be”
   Extrude 19.0 - from the file “Standard MultiPlugin.8bf”
   FastCore Routines 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “FastCore.8bx”
   Fibers 19.0 - from the file “Standard MultiPlugin.8bf”
   Film Grain 19.0 - from the file “Filter Gallery.8bf”
   Filter Gallery 19.0 - from the file “Filter Gallery.8bf”
   Flash 3D 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
   Fresco 19.0 - from the file “Filter Gallery.8bf”
   Glass 19.0 - from the file “Filter Gallery.8bf”
   Glowing Edges 19.0 - from the file “Filter Gallery.8bf”
   Google Earth 4 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
   Graphic Pen 19.0 - from the file “Filter Gallery.8bf”
   Halftone Pattern 19.0 - from the file “Filter Gallery.8bf”
   Halide Bottlenecks 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “HalideBottlenecks.8bx”
   HDRMergeUI 19.0 - from the file “HDRMergeUI.8bf”
   HSB/HSL 19.0 - from the file “Standard MultiPlugin.8bf”
   IFF Format 19.0 - from the file “Standard MultiPlugin.8bf”
   IGES 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
   Ink Outlines 19.0 - from the file “Filter Gallery.8bf”
   JPEG 2000 19.0 - from the file “JPEG2000.8bi”
   Kurtosis 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
   Lens Blur 19.0 - from the file “Lens Blur.8bf”
   Lens Correction 19.0 - from the file “Lens Correction.8bf”
   Lens Flare 19.0 - from the file “Standard MultiPlugin.8bf”
   Liquify 19.0 - from the file “Liquify.8bf”
   Matlab Operation 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “ChannelPort.8bf”
   Maximum 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
   Mean 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
   Measurement Core 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “MeasurementCore.8me”
   Median 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
   Mezzotint 19.0 - from the file “Standard MultiPlugin.8bf”
   Minimum 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
   MMXCore Routines 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “MMXCore.8bx”
   Mosaic Tiles 19.0 - from the file “Filter Gallery.8bf”
   Multiprocessor Support 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “MultiProcessor Support.8bx”
   Neon Glow 19.0 - from the file “Filter Gallery.8bf”
   Note Paper 19.0 - from the file “Filter Gallery.8bf”
   NTSC Colors 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “NTSC Colors.8bf”
   Ocean Ripple 19.0 - from the file “Filter Gallery.8bf”
   OpenEXR 19.0 - from the file “Standard MultiPlugin.8bf”
   Paint Daubs 19.0 - from the file “Filter Gallery.8bf”
   Palette Knife 19.0 - from the file “Filter Gallery.8bf”
   Patchwork 19.0 - from the file “Filter Gallery.8bf”
   Paths to Illustrator 19.0 - from the file “Standard MultiPlugin.8bf”
   PCX 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “PCX.8bi”
   Photocopy 19.0 - from the file “Filter Gallery.8bf”
   Photoshop 3D Engine 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Photoshop3DEngine.8bi”
   Photoshop Touch 19.0 - from the file “PSDX.8bi”
   Picture Package Filter 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “ChannelPort.8bf”
   Pinch 19.0 - from the file “Standard MultiPlugin.8bf”
   Pixar 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Pixar.8bi”
   Plaster 19.0 - from the file “Filter Gallery.8bf”
   Plastic Wrap 19.0 - from the file “Filter Gallery.8bf”
   PLY 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
   Pointillize 19.0 - from the file “Standard MultiPlugin.8bf”
   Polar Coordinates 19.0 - from the file “Standard MultiPlugin.8bf”
   Portable Bit Map 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “PBM.8bi”
   Poster Edges 19.0 - from the file “Filter Gallery.8bf”
   PRC 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
   Radial Blur 19.0 - from the file “Standard MultiPlugin.8bf”
   Radiance 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Radiance.8bi”
   Range 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
   Render Color Lookup Grid 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Export3DLUT.8be”
   Reticulation 19.0 - from the file “Filter Gallery.8bf”
   Ripple 19.0 - from the file “Standard MultiPlugin.8bf”
   Rough Pastels 19.0 - from the file “Filter Gallery.8bf”
   Save for Web 19.0 - from the file “Save for Web.8be”
   ScriptingSupport 19.0 - from the file “ScriptingSupport.8li”
   Shake Reduction 19.0 - from the file “Shake Reduction.8bf”
   Shear 19.0 - from the file “Standard MultiPlugin.8bf”
   Skewness 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
   Smart Blur 19.0 - from the file “Standard MultiPlugin.8bf”
   Smudge Stick 19.0 - from the file “Filter Gallery.8bf”
   Solarize 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Solarize.8bf”
   Spaces 19.0 - from the file “Spaces.8li”
   Spatter 19.0 - from the file “Filter Gallery.8bf”
   Spherize 19.0 - from the file “Standard MultiPlugin.8bf”
   Sponge 19.0 - from the file “Filter Gallery.8bf”
   Sprayed Strokes 19.0 - from the file “Filter Gallery.8bf”
   Stained Glass 19.0 - from the file “Filter Gallery.8bf”
   Stamp 19.0 - from the file “Filter Gallery.8bf”
   Standard Deviation 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
   STL 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
   Sumi-e 19.0 - from the file “Filter Gallery.8bf”
   Summation 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
   Targa 19.0 - from the file “Standard MultiPlugin.8bf”
   Texturizer 19.0 - from the file “Filter Gallery.8bf”
   Tiles 19.0 - from the file “Standard MultiPlugin.8bf”
   Topaz Studio 10.0 - from the file “tlfilterstudiops_x64.8bf”
   Torn Edges 19.0 - from the file “Filter Gallery.8bf”
   Twirl 19.0 - from the file “Standard MultiPlugin.8bf”
   U3D 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
   Underpainting 19.0 - from the file “Filter Gallery.8bf”
   Vanishing Point 19.0 - from the file “VanishingPoint.8bf”
   Variance 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
   Virtual Reality Modeling Language | VRML 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
   Water Paper 19.0 - from the file “Filter Gallery.8bf”
   Watercolor 19.0 - from the file “Filter Gallery.8bf”
   Wave 19.0 - from the file “Standard MultiPlugin.8bf”
   Wavefront|OBJ 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
   WIA Support 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “WIASupport.8li”
   Wind 19.0 - from the file “Standard MultiPlugin.8bf”
   Wireless Bitmap 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “WBMP.8bi”
   ZigZag 19.0 - from the file “Standard MultiPlugin.8bf”
Optional and third party plug-ins:
   Analog Efex Pro 2 2.0.12.12 - from the file “C:\Users\Tony\Desktop\3rd Party Plugins\Nik Collection\Analog Efex Pro 2\Analog Efex Pro 2 (64-Bit)\Analog Efex Pro 2.8bf”
   BackgroundFilter 2.2.21.12 - from the file “C:\Users\Tony\Desktop\3rd Party Plugins\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Background.8bf”
   Color Efex Pro 4 4.3.24.12 - from the file “C:\Users\Tony\Desktop\3rd Party Plugins\Nik Collection\Color Efex Pro 4\Color Efex Pro 4 (64-Bit)\Color Efex Pro 4.8bf”
   Dfine 2 2.2.21.12 - from the file “C:\Users\Tony\Desktop\3rd Party Plugins\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Dfine2.8bf”
   FineStructuresFilter 2.2.21.12 - from the file “C:\Users\Tony\Desktop\3rd Party Plugins\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\FineStructures.8bf”
   HDR Efex Pro 2 2.2.24.12 - from the file “C:\Users\Tony\Desktop\3rd Party Plugins\Nik Collection\HDR Efex Pro 2\HDR Efex Pro 2 (64-Bit)\HDR Efex Pro 2.8bf”
   Hidden NO VERSION - from the file “C:\Program Files (x86)\Topaz Labs\Topaz ReMask 4\Plugins_x64\TopazRemaskAutomation.8li”
   HotPixelsFilter 2.2.21.12 - from the file “C:\Users\Tony\Desktop\3rd Party Plugins\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\HotPixels.8bf”
   Merge to HDR Efex Pro 2 2.2.24.12 - from the file “C:\Users\Tony\Desktop\3rd Party Plugins\Nik Collection\HDR Efex Pro 2\HDR Efex Pro 2 (64-Bit)\HDR Efex Pro 2.8bf”
   ShadowsFilter 2.2.21.12 - from the file “C:\Users\Tony\Desktop\3rd Party Plugins\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Shadows.8bf”
   Sharpener Pro 3: (1) RAW Presharpener 3.1.21.12 - from the file “C:\Users\Tony\Desktop\3rd Party Plugins\Nik Collection\Sharpener Pro 3\Sharpener Pro 3 (64-Bit)\SHP3RPS.8bf”
   Sharpener Pro 3: (2) Output Sharpener 3.1.21.12 - from the file “C:\Users\Tony\Desktop\3rd Party Plugins\Nik Collection\Sharpener Pro 3\Sharpener Pro 3 (64-Bit)\SHP3OS.8bf”
   Silver Efex Pro 2 2.2.24.12 - from the file “C:\Users\Tony\Desktop\3rd Party Plugins\Nik Collection\Silver Efex Pro 2\Silver Efex Pro 2 (64-Bit)\Silver Efex Pro 2.8bf”
   SkinFilter 2.2.21.12 - from the file “C:\Users\Tony\Desktop\3rd Party Plugins\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Skin.8bf”
   SkyFilter 2.2.21.12 - from the file “C:\Users\Tony\Desktop\3rd Party Plugins\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Sky.8bf”
   StrongNoiseFilter 2.2.21.12 - from the file “C:\Users\Tony\Desktop\3rd Party Plugins\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\StrongNoise.8bf”
   Topaz Adjust 5 10.0 - from the file “C:\Program Files (x86)\Topaz Labs\Topaz Adjust 5\Plugins_x64\tladjust5ps_x64.8bf”
   Topaz B&W Effects 2 10.0 - from the file “C:\Program Files (x86)\Topaz Labs\Topaz BW 2\Plugins_x64\tlbw2ps_x64.8bf”
   Topaz Clarity 10.0 - from the file “C:\Program Files (x86)\Topaz Labs\Topaz Clarity\Plugins_x64\tlclarityps_x64.8bf”
   Topaz Clean 3 10.0 - from the file “C:\Program Files (x86)\Topaz Labs\Topaz Clean 3\Plugins_x64\tlclean3ps_x64.8bf”
   Topaz DeJpeg 4 10.0 - from the file “C:\Program Files (x86)\Topaz Labs\Topaz DeJpeg 4\Plugins_x64\tldejpeg4ps_x64.8bf”
   Topaz DeNoise 5 10.0 - from the file “C:\Program Files (x86)\Topaz Labs\Topaz DeNoise 5\Plugins_x64\tldenoise5ps_x64.8bf”
   Topaz Detail 3 10.0 - from the file “C:\Program Files (x86)\Topaz Labs\Topaz Detail 3\Plugins_x64\tldetail3ps_x64.8bf”
   Topaz InFocus 10.0 - from the file “C:\Program Files (x86)\Topaz Labs\Topaz InFocus\Plugins_x64\tlinfocusps_x64.8bf”
   Topaz Lens Effects 10.0 - from the file “C:\Program Files (x86)\Topaz Labs\Topaz Lens Effects\Plugins_x64\tllenseffectsps_x64.8bf”
   Topaz photoFXlab 10.0 - from the file “C:\Program Files (x86)\Topaz Labs\Applications\64Bit\Topaz Plug-ins\tlphotoFXlabps_x64.8bf”
   Topaz ReMask 4 10.0 - from the file “C:\Program Files (x86)\Topaz Labs\Topaz ReMask 4\Plugins_x64\tlremask4ps_x64.8bf”
   Topaz ReStyle 10.0 - from the file “C:\Program Files (x86)\Topaz Labs\Topaz ReStyle\Plugins_x64\tlrestyleps_x64.8bf”
   Topaz Simplify 4 10.0 - from the file “C:\Program Files (x86)\Topaz Labs\Topaz Simplify 4\Plugins_x64\tlsimplify4ps_x64.8bf”
   Topaz Star Effects 10.0 - from the file “C:\Program Files (x86)\Topaz Labs\Topaz Star Effects\Plugins_x64\tlstareffectsps_x64.8bf”
   Viveza 2 2.1.21.12 - from the file “C:\Users\Tony\Desktop\3rd Party Plugins\Nik Collection\Viveza 2\Viveza 2 (64-Bit)\Viveza2.8bf”
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load:
   Analog Efex Pro 2 NO VERSION -  - from the file “C:\Users\Tony\Desktop\3rd Party Plugins\Nik Collection\Analog Efex Pro 2\Analog Efex Pro 2.8bf”
   BackgroundFilter NO VERSION -  - from the file “C:\Users\Tony\Desktop\3rd Party Plugins\Nik Collection\Dfine 2\Background.8bf”
   Color Efex Pro 4 NO VERSION -  - from the file “C:\Users\Tony\Desktop\3rd Party Plugins\Nik Collection\Color Efex Pro 4\Color Efex Pro 4.8bf”
   Dfine 2 NO VERSION -  - from the file “C:\Users\Tony\Desktop\3rd Party Plugins\Nik Collection\Dfine 2\Dfine2.8bf”
   FineStructuresFilter NO VERSION -  - from the file “C:\Users\Tony\Desktop\3rd Party Plugins\Nik Collection\Dfine 2\FineStructures.8bf”
   HDR Efex Pro 2 NO VERSION -  - from the file “C:\Users\Tony\Desktop\3rd Party Plugins\Nik Collection\HDR Efex Pro 2\HDR Efex Pro 2.8bf”
   HotPixelsFilter NO VERSION -  - from the file “C:\Users\Tony\Desktop\3rd Party Plugins\Nik Collection\Dfine 2\HotPixels.8bf”
   Merge to HDR Efex Pro 2 NO VERSION -  - from the file “C:\Users\Tony\Desktop\3rd Party Plugins\Nik Collection\HDR Efex Pro 2\HDR Efex Pro 2.8bf”
   ShadowsFilter NO VERSION -  - from the file “C:\Users\Tony\Desktop\3rd Party Plugins\Nik Collection\Dfine 2\Shadows.8bf”
   Sharpener Pro 3: (1) RAW Presharpener NO VERSION -  - from the file “C:\Users\Tony\Desktop\3rd Party Plugins\Nik Collection\Sharpener Pro 3\SHP3RPS.8bf”
   Sharpener Pro 3: (2) Output Sharpener NO VERSION -  - from the file “C:\Users\Tony\Desktop\3rd Party Plugins\Nik Collection\Sharpener Pro 3\SHP3OS.8bf”
   Silver Efex Pro 2 NO VERSION -  - from the file “C:\Users\Tony\Desktop\3rd Party Plugins\Nik Collection\Silver Efex Pro 2\Silver Efex Pro 2.8bf”
   SkinFilter NO VERSION -  - from the file “C:\Users\Tony\Desktop\3rd Party Plugins\Nik Collection\Dfine 2\Skin.8bf”
   SkyFilter NO VERSION -  - from the file “C:\Users\Tony\Desktop\3rd Party Plugins\Nik Collection\Dfine 2\Sky.8bf”
   StrongNoiseFilter NO VERSION -  - from the file “C:\Users\Tony\Desktop\3rd Party Plugins\Nik Collection\Dfine 2\StrongNoise.8bf”
   Viveza 2 NO VERSION -  - from the file “C:\Users\Tony\Desktop\3rd Party Plugins\Nik Collection\Viveza 2\Viveza2.8bf”
Extensions:
   com.adobe.inapp.purchase  2.11.27 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\purchase.html”
   Libraries  2.11.27 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\index.html”
   Start  2.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.ccx.start\index.html”
   Export As  3.0.13 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
   com.adobe.Butler.backend  2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.Butler.backend\index.html”
   New Document  2.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.ccx.fnft\fnft.html”
   InstaMask 1.0  1.0.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.JM.InstaMask\index.html”
   ADPpanel+Pro  3.3.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\adppanelpluspro\index.html”
   Adobe Color Themes  6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
   Raya Pro 2.0  2.0.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\RP - Manual Install\index.html”
Installed TWAIN devices: NONE
Hi
I don't see anything in that system info that would stop Select & Mask.
I would suggest contacting Adobe (support details are at the top of the forum page). They will be able to work directly with you on your system and hopefully resolve your issue.
Dave
