I am trying to export a 36 minute video that I am planning on uploading to YouTube. The footage was captured with an Elgato in 720p and then imported into PP.
When I attempted to export as a H.264 (which I have seen as the suggested format for YouTube videos) with the YouTube 720p HD preset selected the video produced is listed as 0:00 in length with a minuscule file size. I have tried pressing 'queue' and going through the encoder as well as hitting 'export' for the straight export.
Even now as I look at the 'export settings' page it shows me that the estimated file size is 33 KB which is much too small for a video of this size.
Any advice on what I am doing wrong would be much appreciated. Thanks!
If you look at your source range: it is set to 1 frame (left tab bottom)
Set it to Entire Sequence.
What do you have selected as the export area?
Paste a print screen of your export window into your reply so people may see what you are doing
That is your edit screen, not your export screen
In your export screen, what do you have selected for export?
This is my export screen.
Thanks for the help! I knew I was missing something
...or go to the Timeline and remove the In and Out point you have there by pressing Ctrl+Shift+A.
Dont you mean ctrl+shift+X.
Yes Ctrl+Shift+X is what i meant. I still use the old one since it is universal.
