Unzip a file
Nov 10, 2017 Nov 10, 2017
Hi Team,
Is there any possibility of unzipping a file from desktop and execute an action through PS.
Actions and scripting
5.6K
Engaged , Nov 11, 2017 Nov 11, 2017
If you're familiar with command-line zip (see Unzipping Files Using Terminal | Mac Tricks And Tips for info), you can write the needed lines into a string and then pass it to the app.system() function, for instance:
var cmd = "cd ~/Desktop/srcFolder\n" +
          "unzip -o test.zip -d ~/Desktop/destFolder";
app.system(cmd);
Hope this helps,
Davide
Adobe
Engaged ,
app.system(cmd);
Hope this helps,
Davide
Davide Barranca - PS developer and author
www.ps-scripting.com
Nov 13, 2017 Nov 13, 2017
Thanks Davide!
Engaged ,
Hi Davide,
Is this possible to unzip file from sever..? since I used that code and getting error..
var cmd = "cd //NEWSERVER/Source files\n" + "unzip -o test.zip -d ~/Desktop/dest Folder";
app.system(cmd);
yajiv
Engaged ,
Nov 15, 2017 Nov 15, 2017
Hi Yajiv,
what about the following?
var cmd = "unzip -o //NEWSERVER/Source files/test.zip -d ~/Desktop/dest Folder";
app.system(cmd);
People's Champ ,
Names with spaces must be quoted. For two or more commands, use "cmd / c" and "&".
That's how it should work (did not check it).
var cmd = "cmd /c cd \"//NEWSERVER/Source files\"" + " & "+ "unzip -o test.zip -d \"~/Desktop/dest Folder\"";
app.system(cmd);
Engaged ,
Hi Davide and r-bin,
Thank you for the prompt response and sorry for the late reply.
I have tested both code and result is same not working. Kindly advice
try{
var cmd = "cmd /c cd \"~/Desktop/src Folder\"" + " & "+ "unzip -o Team FP.zip -d \"~/Desktop/dest Folder\"";
app.system(cmd);
}catch(er){alert(er)}
-yajiv
People's Champ ,
Nov 16, 2017 Nov 16, 2017
Both commands work (verified)
var cmd1 = "unzip -o \"\\\\Server\\Folder\\SubFolder\\a.zip\" -d \"%USERPROFILE%\\Desktop\\dest Folder\""
var cmd2 = "pushd \"\\\\Server\\Folder\\SubFolder\"" + " & unzip -o \"a.zip\" -d \"%USERPROFILE%\\Desktop\\dest Folder\""
app.system(cmd1 + " & pause");
app.system(cmd2 + " & pause");
Engaged ,
Hi r-bin,
Thank you so much for the script. I have done some modification on existing script and the script working fine.
I have changed "/Users/yajiv/Desktop" instead of "~/Desktop"
    UnzipFiles("/Users/yajiv/Desktop/src Folder/TestFP.zip","/Users/yajiv/Desktop/dest Folder");
    function UnzipFiles(ZipFile,DestFolder){
        var cmd = "unzip \""+File(ZipFile).fsName+"\" -d \""+DestFolder+"\"";
        app.system(cmd);
        var tmpFile=File(DestFolder+"/ticket.xml");
        if(tmpFile.exists) tmpFile.remove();
        var tmpFolder=Folder(DestFolder+"/__MACOSX");
        if(tmpFolder.exists) tmpFolder.remove();
You help much appreciated..
-yajiv
Mar 18, 2018 Mar 18, 2018
It does work in cmd.exe:
"C:\Program Files (x86)\WinRAR\unrar.exe" x "%USERPROFILE%\Desktop\test.rar"
Why it doesn't work in ESTK with targeted Photoshop:
system('"C:\\Program Files (x86)\\WinRAR\\unrar.exe" x "%USERPROFILE%\\Desktop\\test.rar"')
Moreover I can create bat.bat file that I can run from desktop:
cmnd = '"C:\\Program Files (x86)\\WinRAR\\unrar.exe" x "%USERPROFILE%\\Desktop\\test.rar"'
fle = File(Folder.desktop + '/bat.bat'), fle.open('w'), fle.write(cmnd), fle.close()
But when I add to above code:
fle.execute()
only bat.bat is created, but not executed 😕
When bat.bat on desktop is created and then I run from ESTK:
File(Folder.desktop + '/bat.bat').execute()
it's executed, but cmd.exe acts differently, I mean asks me some questions. Even if I answer for them files are still unrared!
People's Champ ,
Try this
var cmd = '"C:\\Program Files (x86)\\WinRAR\\unrar.exe" x "%USERPROFILE%\\Desktop\\test.rar"';
system('"' + cmd + '"')
This will extract the files to the current folder. And the current folder is the path to Photoshop.exe. It is necessary to have rights.
In the second case, everything is also extracted to the Photoshop folder.
Try this
cmnd = '"C:\\Program Files (x86)\\WinRAR\\unrar.exe" x "%USERPROFILE%\\Desktop\\test.rar" "%USERPROFILE%\\Desktop"'
fle.execute()
To be very honest before you posted your solution my last try had to be with additional quotes (so like in your example), as I tried something like it in deep past and it worked, but then looked once again at code and found, no way, that has no sense - it all looks like that should work. So I didn't eventually try that trick. Even if I did I still had problem. Because your first code does not work. It works only when like in second code you posted the destination folder for unrared content is specified so:
system('""C:\\Program Files (x86)\\WinRAR\\unrar.exe" x "%USERPROFILE%\\Desktop\\test.rar" "%USERPROFILE%\\Desktop""')
That specified destination that should be added at end of code I saw in some exampes I googled, but I did not use that as trying it without it directly from Command Prompt showed it is not needed. Well I thought if in Command Line that is no needed then why that should be used in ESTK. That's not logical for me. THX again that I had no to loose much time on it.
People's Champ ,
At me all works fine and files are extracted in a folder
C: \ Program Files \ Adobe \ Adobe Photoshop CS6.
I knowingly said about access rights. Or run photoshop with administrator rights
Ah I am sorry, I missed that sentence about unraring to Photoshop folder. Yes I checked that, you are right. They were there. But like I found if you want to use system (so no .bat method) to extract your files to specified spot in your system then you can add third path at end of command code (so like in your .bat example). I'm not sure that did work for you, but for me did, and that what I wanted to get
People's Champ ,
By the way, you can play with this
var comspec = $.getenv("comspec")
alert(comspec)
$.setenv("comspec", "C:\\Windows\\notepad.exe");
system("1234")
$.setenv(somprec); // wrong
EDIT:
$.setenv("comspec", comspec) //right
Feb 18, 2021 Feb 18, 2021
I understand this code. It opens notepad and ask me if I want to save document as \c 1234.txt?
