Hi Everyone,
I'm using Photoshop CC 2018 (latest update two days ago). I would like enable access to Oil Paint - the option is grayed out. Preferences -> Performance -> Advanced Settings -> Use OpenCL is also grayed out. I have made sure my document is in RGB color mode. I am running Photoshop in 64-bit mode. My OS is 64-bit. All my patches and drivers are up to date/latest versions.
Machine specs are as follows:
Processor: Intel Core i5-3450
RAM: Corsair Vengeance, 16GB DDR3
PSU: Thermaltake Toughpower 750W
SSD: Samsung 850 EVO (primary)
OS: Windows 7 Pro 64-bit
GPU: NVIDIA GeForce GTX 1050 Ti
NVRAM: 4GB DDR5
GLVersion=4.5
CLVersion=1.2
I know this question has been asked many times but I cannot find a proper solution. Can anyone solve this issue - how do I enable OpenCL and Oil Paint?
Here is a snapshot of my System Info:
Adobe Photoshop Version: 19.0 20170929.r.165 2017/09/29: 1138933 x64
Number of Launches: 1
Operating System: Windows 7 64-bit
Version: 7 SP1 6.1.7601.23915
System architecture: Intel CPU Family:6, Model:10, Stepping:9 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX
Physical processor count: 4
Processor speed: 3192 MHz
Built-in memory: 16339 MB
Free memory: 3249 MB
Memory available to Photoshop: 14526 MB
Memory used by Photoshop: 69 %
Surface Dial: Enabled.
Alias Layers: Disabled.
Modifier Palette: Disabled.
Highbeam: Enabled.
Image tile size: 1024K
Image cache levels: 5
Font Preview: Medium
TextComposer: Latin
Display: 1
Display Bounds: top=0, left=0, bottom=1200, right=1920
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
glgpu[0].GLVersion="4.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=4096
glgpu[0].GLName="NVIDIA GeForce GTX 1050 Ti"
glgpu[0].GLVendor="NVIDIA Corporation"
glgpu[0].GLVendorID=4318
glgpu[0].GLDriverVersion="23.21.13.8813"
glgpu[0].GLRectTextureSize=32768
glgpu[0].GLRenderer="GeForce GTX 1050 Ti/PCIe/SSE2"
glgpu[0].GLRendererID=7298
glgpu[0].HasGLNPOTSupport=1
glgpu[0].GLDriver="nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um"
glgpu[0].GLDriverDate="20171027000000.000000-000"
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.60 NVIDIA"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[65536]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
License Type: Subscription
Serial number: 96040250179453001030
GUIDBucket:
Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\
Temporary file path: C:\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
Startup, 628.7G, 161.2G free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\Plug-Ins\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Plug-Ins\
Turn your picture to a JPG then into a 8 bit's a channel ie
Image >Mode > 8 bit.....then the oil paint option will work.
I am having the same problem and I was able to turn on OpenCL in the performance properties on this same computer system before. I know my computer and graphic card supports it. It has nothing to do the photo. You can not turn it on in the preferences. It is possible the 2018 version of Photoshop CC has a bug?
Number of Launches: 16
Operating System: Windows 10 64-bit
Version: 10 or greater 10.0.16299.15
System architecture: Intel CPU Family:6, Model:12, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
Logical processor count: 8
Processor speed: 3998 MHz
Built-in memory: 16324 MB
Free memory: 7159 MB
Memory available to Photoshop: 14401 MB
Memory used by Photoshop: 60 %
Modifier Palette: Enabled.
Highbeam: Disabled.
Image cache levels: 4
TextComposer: Latin
Display: 1
Display: 2
Display Bounds: top=0, left=1920, bottom=1200, right=3840
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumNativeGPUs=0
glgpu[0].GLName="NVIDIA GeForce GTX 970"
glgpu[0].GLRectTextureSize=16384
glgpu[0].GLRenderer="GeForce GTX 970/PCIe/SSE2"
glgpu[0].GLRendererID=5058
glgpu[0].GLDriver="C:\WINDOWS\System32\DriverStore\FileRepository\nv_ref_pubwu.inf_amd64_2e7fa54192fe16d0\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_ref_pubwu.inf_amd64_2e7fa54192fe16d0\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_ref_pubwu.inf_amd64_2e7fa54192fe16d0\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_ref_pubwu.inf_amd64_2e7fa54192fe16d0\nvldumdx.dll"
Serial number: 96040816359118129811
GUIDBucket:
Application folder: D:\Program Files\Adobe Photoshop CC 2018\
Temporary file path: C:\Users\cpgilles\AppData\Local\Temp\
Scratch volume(s):
Startup, 476.4G, 370.0G free
Required Plug-ins folder: D:\Program Files\Adobe Photoshop CC 2018\Required\Plug-Ins\
Primary Plug-ins folder: D:\Program Files\Adobe Photoshop CC 2018\Plug-Ins\
Installed components:
A3DLIBS.dll A3DLIB Dynamic Link Library 9.2.0.112
ACE.dll ACE 2017/09/19-18:51:44 79.586793 79.586793
AdbePM.dll PatchMatch 2016/11/03:19:48:57 1.578146 1.578146
AdobeLinguistic.dll Adobe Linguisitc Library 10.0.0
AdobeOwl.dll Adobe Owl 5.2.11
AdobePDFL.dll PDFL 2017/09/01-01:08:01 79.239219 79.239219
AdobePIP.dll Adobe Product Improvement Program 7.4.1.60.45263
AdobeSVGAGM.dll AdobeSVGAGM 79.586793 79.586793
AdobeXMP.dll Adobe XMP Core 2017/07/13-01:06:39 79.160924 79.160924
AdobeXMPFiles.dll Adobe XMP Files 2017/07/13-01:06:39 79.160924 79.160924
AdobeXMPScript.dll Adobe XMP Script 2017/07/13-01:06:39 79.160924 79.160924
adobe_caps.dll Adobe CAPS 10,0,0,6
AGM.dll AGM 2017/09/19-18:51:44 79.586793 79.586793
ahclient.dll AdobeHelp Dynamic Link Library 3.0.0.6
AIDE.dll AIDE 2016/05/27-01:08:49 79.574279 79.574279
amtlib.dll AMTLib (64 Bit) 10.0.0.221 BuildVersion: 10.0; BuildDate: Tue Aug 1 2017 8:28:8) 1.000000
ARE.dll ARE 2017/09/19-18:51:44 79.586793 79.586793
AXE8SharedExpat.dll AXE8SharedExpat 2015/03/13-23:40:54 79.562390 79.562390
AXEDOMCore.dll AXEDOMCore 2015/03/13-23:40:54 79.562390 79.562390
Bib.dll BIB 2017/09/19-18:51:44 79.586793 79.586793
BIBUtils.dll BIBUtils 2017/09/19-18:51:44 79.586793 79.586793
boost_date_time.dll photoshopdva 11.1.0
boost_filesystem.dll photoshopdva 11.1.0
boost_signals.dll photoshopdva 11.1.0
boost_system.dll photoshopdva 11.1.0
boost_threads.dll photoshopdva 11.1.0
cg.dll NVIDIA Cg Runtime 3.0.00007
cgGL.dll NVIDIA Cg Runtime 3.0.00007
CITThreading.dll Adobe CITThreading 2.1.0.1 2.1.0.1
CoolType.dll CoolType 2017/09/19-18:51:44 79.586793 79.586793
CRClient.dll Adobe Crash Reporter Client DLL 1.6.1.0
dnssd.dll Bonjour 3,0,0,2
dvaaudiodevice.dll photoshopdva 11.1.0
dvacore.dll photoshopdva 11.1.0
dvacrashhandler.dll Adobe Audition CC 2017 10.0.0
dvamarshal.dll photoshopdva 11.1.0
dvamediatypes.dll photoshopdva 11.1.0
dvametadata.dll photoshopdva 11.1.0
dvametadataapi.dll photoshopdva 11.1.0
dvametadataui.dll photoshopdva 11.1.0
dvaplayer.dll photoshopdva 11.1.0
dvatransport.dll photoshopdva 11.1.0
dvaui.dll photoshopdva 11.1.0
dvaunittesting.dll photoshopdva 11.1.0
dynamiclink.dll photoshopdva 11.1.0
ExtendScript.dll ExtendScript 2017/08/31-12:13:14 81.1133690 81.1133690
icucnv40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icudt40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icuuc40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
igestep30.dll IGES Reader 9.3.0.113
imslib.dll IMSLib DLL 10.0.0.22
JP2KLib.dll JP2KLib 2017/08/23-01:11:25 79.267771 79.267771
libifcoremd.dll Intel(r) Visual Fortran Compiler 10.0 (Update A)
libiomp5md.dll Intel(R) OpenMP* Runtime Library 5.0
libmmd.dll Intel(R) C/C++/Fortran Compiler 17.0.0
LogSession.dll LogSession 7.4.1.60.45263
mediacoreif.dll photoshopdva 11.1.0
MPS.dll MPS 2017/09/01-01:08:01 79.586120 79.586120
pdfsettings.dll Adobe PDFSettings 1.04
Photoshop.dll Adobe Photoshop CC 2018 19.0
Plugin.dll Adobe Photoshop CC 2018 19.0
PlugPlugExternalObject.dll Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit) 8.0.0
PlugPlugOwl.dll Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit) 8.0.0.55
PSArt.dll Adobe Photoshop CC 2018 19.0
PSCloud.dll 1.0.0.1
PSViews.dll Adobe Photoshop CC 2018 19.0
SCCore.dll ScCore 2017/08/31-12:13:14 81.1133690 81.1133690
SVGRE.dll SVGRE 79.586793 79.586793
svml_dispmd.dll Intel(R) C/C++/Fortran Compiler 17.0.0
tbb.dll Intel(R) Threading Building Blocks for Windows 2017, 0, 2017, 0118
tbbmalloc.dll Intel(R) Threading Building Blocks for Windows 2017, 0, 2017, 0118
TfFontMgr.dll FontMgr 9.3.0.113
TfKernel.dll Kernel 9.3.0.113
TFKGEOM.dll Kernel Geom 9.3.0.113
TFUGEOM.dll Adobe, UGeom© 9.3.0.113
updaternotifications.dll Adobe Updater Notifications Library 10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME) 10.0.0.1
VulcanControl.dll Vulcan Application Control Library 5.3.0.16
VulcanMessage5.dll Vulcan Message Library 5.3.0.16
WRServices.dll WRServices Thu Jan 07 2016 04:50:10 Build 0.21960 0.21960
wu3d.dll U3D Writer 9.3.0.113
Required plug-ins:
3D Studio 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
Accented Edges 19.0 - from the file “Filter Gallery.8bf”
Adaptive Wide Angle 19.0 - from the file “Adaptive Wide Angle.8bf”
Angled Strokes 19.0 - from the file “Filter Gallery.8bf”
Average 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Average.8bf”
Bas Relief 19.0 - from the file “Filter Gallery.8bf”
BMP 19.0 - from the file “Standard MultiPlugin.8bf”
Camera Raw 10.0 - from the file “Camera Raw.8bi”
Camera Raw Filter 10.0 - from the file “Camera Raw.8bi”
Chalk && Charcoal 19.0 - from the file “Filter Gallery.8bf”
Chrome 19.0 - from the file “Filter Gallery.8bf”
Cineon 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Cineon.8bi”
Clouds 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Clouds.8bf”
Collada 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
Color Halftone 19.0 - from the file “Standard MultiPlugin.8bf”
Colored Pencil 19.0 - from the file “Filter Gallery.8bf”
CompuServe GIF 19.0 - from the file “Standard MultiPlugin.8bf”
Conté Crayon 19.0 - from the file “Filter Gallery.8bf”
Craquelure 19.0 - from the file “Filter Gallery.8bf”
Crop and Straighten Photos 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “CropPhotosAuto.8li”
Crop and Straighten Photos Filter 19.0 - from the file “Standard MultiPlugin.8bf”
Crosshatch 19.0 - from the file “Filter Gallery.8bf”
Crystallize 19.0 - from the file “Standard MultiPlugin.8bf”
Cutout 19.0 - from the file “Filter Gallery.8bf”
Dark Strokes 19.0 - from the file “Filter Gallery.8bf”
De-Interlace 19.0 - from the file “Standard MultiPlugin.8bf”
Dicom 19.0 - from the file “Dicom.8bi”
Difference Clouds 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Clouds.8bf”
Diffuse Glow 19.0 - from the file “Filter Gallery.8bf”
Displace 19.0 - from the file “Standard MultiPlugin.8bf”
Dry Brush 19.0 - from the file “Filter Gallery.8bf”
Eazel Acquire 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “EazelAcquire.8ba”
Entropy 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
Export Color Lookup Tables 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Export3DLUT.8be”
Extrude 19.0 - from the file “Standard MultiPlugin.8bf”
FastCore Routines 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “FastCore.8bx”
Fibers 19.0 - from the file “Standard MultiPlugin.8bf”
Film Grain 19.0 - from the file “Filter Gallery.8bf”
Filter Gallery 19.0 - from the file “Filter Gallery.8bf”
Flash 3D 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
Fresco 19.0 - from the file “Filter Gallery.8bf”
Glass 19.0 - from the file “Filter Gallery.8bf”
Glowing Edges 19.0 - from the file “Filter Gallery.8bf”
Google Earth 4 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
Graphic Pen 19.0 - from the file “Filter Gallery.8bf”
Halftone Pattern 19.0 - from the file “Filter Gallery.8bf”
Halide Bottlenecks 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “HalideBottlenecks.8bx”
HDRMergeUI 19.0 - from the file “HDRMergeUI.8bf”
HSB/HSL 19.0 - from the file “Standard MultiPlugin.8bf”
IFF Format 19.0 - from the file “Standard MultiPlugin.8bf”
IGES 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
Ink Outlines 19.0 - from the file “Filter Gallery.8bf”
JPEG 2000 19.0 - from the file “JPEG2000.8bi”
Kurtosis 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
Lens Blur 19.0 - from the file “Lens Blur.8bf”
Lens Correction 19.0 - from the file “Lens Correction.8bf”
Lens Flare 19.0 - from the file “Standard MultiPlugin.8bf”
Liquify 19.0 - from the file “Liquify.8bf”
Matlab Operation 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “ChannelPort.8bf”
Maximum 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
Mean 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
Measurement Core 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “MeasurementCore.8me”
Median 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
Mezzotint 19.0 - from the file “Standard MultiPlugin.8bf”
Minimum 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
MMXCore Routines 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “MMXCore.8bx”
Mosaic Tiles 19.0 - from the file “Filter Gallery.8bf”
Multiprocessor Support 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “MultiProcessor Support.8bx”
Neon Glow 19.0 - from the file “Filter Gallery.8bf”
Note Paper 19.0 - from the file “Filter Gallery.8bf”
NTSC Colors 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “NTSC Colors.8bf”
Ocean Ripple 19.0 - from the file “Filter Gallery.8bf”
OpenEXR 19.0 - from the file “Standard MultiPlugin.8bf”
Paint Daubs 19.0 - from the file “Filter Gallery.8bf”
Palette Knife 19.0 - from the file “Filter Gallery.8bf”
Patchwork 19.0 - from the file “Filter Gallery.8bf”
Paths to Illustrator 19.0 - from the file “Standard MultiPlugin.8bf”
PCX 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “PCX.8bi”
Photocopy 19.0 - from the file “Filter Gallery.8bf”
Photoshop 3D Engine 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Photoshop3DEngine.8bi”
Photoshop Touch 19.0 - from the file “PSDX.8bi”
Picture Package Filter 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “ChannelPort.8bf”
Pinch 19.0 - from the file “Standard MultiPlugin.8bf”
Pixar 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Pixar.8bi”
Plaster 19.0 - from the file “Filter Gallery.8bf”
Plastic Wrap 19.0 - from the file “Filter Gallery.8bf”
PLY 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
Pointillize 19.0 - from the file “Standard MultiPlugin.8bf”
Polar Coordinates 19.0 - from the file “Standard MultiPlugin.8bf”
Portable Bit Map 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “PBM.8bi”
Poster Edges 19.0 - from the file “Filter Gallery.8bf”
PRC 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
Radial Blur 19.0 - from the file “Standard MultiPlugin.8bf”
Radiance 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Radiance.8bi”
Range 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
Render Color Lookup Grid 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Export3DLUT.8be”
Reticulation 19.0 - from the file “Filter Gallery.8bf”
Ripple 19.0 - from the file “Standard MultiPlugin.8bf”
Rough Pastels 19.0 - from the file “Filter Gallery.8bf”
Save for Web 19.0 - from the file “Save for Web.8be”
ScriptingSupport 19.0 - from the file “ScriptingSupport.8li”
Shake Reduction 19.0 - from the file “Shake Reduction.8bf”
Shear 19.0 - from the file “Standard MultiPlugin.8bf”
Skewness 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
Smart Blur 19.0 - from the file “Standard MultiPlugin.8bf”
Smudge Stick 19.0 - from the file “Filter Gallery.8bf”
Solarize 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Solarize.8bf”
Spaces 19.0 - from the file “Spaces.8li”
Spatter 19.0 - from the file “Filter Gallery.8bf”
Spherize 19.0 - from the file “Standard MultiPlugin.8bf”
Sponge 19.0 - from the file “Filter Gallery.8bf”
Sprayed Strokes 19.0 - from the file “Filter Gallery.8bf”
Stained Glass 19.0 - from the file “Filter Gallery.8bf”
Stamp 19.0 - from the file “Filter Gallery.8bf”
Standard Deviation 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
STL 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
Sumi-e 19.0 - from the file “Filter Gallery.8bf”
Summation 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
Targa 19.0 - from the file “Standard MultiPlugin.8bf”
Texturizer 19.0 - from the file “Filter Gallery.8bf”
Tiles 19.0 - from the file “Standard MultiPlugin.8bf”
Torn Edges 19.0 - from the file “Filter Gallery.8bf”
Twirl 19.0 - from the file “Standard MultiPlugin.8bf”
U3D 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
Underpainting 19.0 - from the file “Filter Gallery.8bf”
Vanishing Point 19.0 - from the file “VanishingPoint.8bf”
Variance 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
Virtual Reality Modeling Language | VRML 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
Water Paper 19.0 - from the file “Filter Gallery.8bf”
Watercolor 19.0 - from the file “Filter Gallery.8bf”
Wave 19.0 - from the file “Standard MultiPlugin.8bf”
Wavefront|OBJ 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
WIA Support 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “WIASupport.8li”
Wind 19.0 - from the file “Standard MultiPlugin.8bf”
Wireless Bitmap 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “WBMP.8bi”
ZigZag 19.0 - from the file “Standard MultiPlugin.8bf”
Optional and third party plug-ins: NONE
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load: NONE
Extensions:
com.adobe.Butler.backend 2.0.0 - from the file “D:\Program Files\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.Butler.backend\index.html”
com.adobe.inapp.purchase 2.11.27 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_11_27\purchase.html”
New Document 2.1.0 - from the file “D:\Program Files\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.ccx.fnft\fnft.html”
Libraries 2.11.27 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_11_27\index.html”
Start 2.1.0 - from the file “D:\Program Files\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.ccx.start\index.html”
Adobe Color Themes 6.1.0 - from the file “D:\Program Files\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
Export As 3.0.13 - from the file “D:\Program Files\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
Installed TWAIN devices: NONE
Process the JPEG in 8 bit/Channel .
Sent from Mail for Windows 10
It has nothing to do with the type of photo it is although I did try this and it did not work. The OpenCL option is grayed out in the performance section of preferences. Until Photoshop recognizes the video card as being OpenCL compliant this feature will not work. I created many Oil Painting images with Photoshop CC 2017 on this same computer. This feature stopped working with Photoshop CC 2018.
Thanks for the reply though.
Have you tried downloading and installing the latest driver for your GPU, I have often found that re-installing the driver can sometimes fix this issue
I decided to install Photoshop CC 2017 on a different but very similar computer. Same hardware. The OpenlCL is checked in the performance preferences and the Oil Paint filter is active. Then I tried installing Photoshop CC 2017 on the same computer that had been upgraded to Photoshop CC 2018 and the 2017 version is exhibiting the same problem. The OpenCL is NOT an option. Both computers are using the same version of NVidia driver. It is not the absolute latest but the latest version certified for Windows 10. I tried to update the driver in Windows 10 and it said it was the latest version. I don't think the driver version is the problem. Adobe changed something with Photoshop CC 2018 that affected OpenCL and now it will not work on any version of Photoshop. I hope Adobe fixes this soon.
The only thing I can suggest is un-installing the Nvidia drivers from Windows Control Panel
Download the latest Certified driver from here and install that.
Advanced Driver Search | NVIDIA
You could also try this
Use the Creative Cloud Cleaner Tool to solve installation problems
Well after much thought and concern I downloaded and installed the latest NVidia driver. They just loaded a new version. That fixed the problem. I am reluctant to install drivers outside of the Windows updates because of the problems they can cause. I rarely have problems if I stick with the versions certified by Microsoft. Hopefully this will not cause other app issues.
Thanks for everyone's help.
It worked on mine,this stuff drives you nuts doesn’t!
Russell Donkin
Sent from my iPhone
