Thank you for putting those system attributes at the
beginning of the post.
Whilst I believe there could be some degree of mix and match
between the version of RH and RH Server (or Enginge), Version 7 is
different. RH moved to unicode and needs Server 7. You need to
upgrade that as well.
UPDATE
That is my understanding although it doesn't seem logical
that sometimes your process works and sometimes it does not. Maybe
a Server 7 guru can confirm. If not, check before you buy, but I am
reasonably sure what I have said is correct.
