Hello everyone,
I try to fix my problem by write and try many things, but nothing works. So I hope here I can find someone to help
First, when I try to open my project, I got this message :
Sorry, that's in french but here is the translation :
"PAUBEL.psd" contains a built-in color profile that does not match the RGB workspace.
Incorporated : sRGB ...
RGB monitor-display workspace.
Choose :
- Prefer incorporated profil (instead of the workspace)
- convert document colors to workspace
- delete embedded profile (no color management)"
And here is my problem when it finally open the project : (I tried open with the 3 options)
( the problem : red pixel comes )
(and without any layer, the red pixel still exist)
For information, that is my color's settings :
I got the Photoshop 2014
Does anyone know why there is these red pixel ??
I precise, when I export project en JPEG for example, these red pixel disappears / When I creat a new project, these red pixel disappears
Thanks for help
Pierre
You seem to be in Quick Mask mode.
Press Q to get back to normal mode.
Hi Pierre
It is hard to tell what is wrong with your document but you do need to change your color settings - then try again
1. Change the RGB (RVB) working space to sRGB IEC1966-2.1 or Adobe RGB (1998) - if you are unsure choose the sRGB option. You do not want it set to your monitor display profile.
2. Change your color Management policies to "Preserve Embedded Profiles"
Dave
Hi Jesper !
First, thanks a lot for your answer !!
My Gamut Warning is of (no check mark) and in my preferences > Transparency, my gamut warning color is grey.. I can't understand why there is these red mark.
Hey Dave !!
Sorry I did wrong handling, I though my previous answer was for Jesper.
But thanks for your answer !
I change setting as you say, and so no warning message appear now, so it's cool ! But, the red pixel still persist
I don't understand what is it.
Hi Pierre,
Is Gamut Warning enabled (does it have a check mark) in the View menu?
You can set the Gamut Warning color in Preferences > Transparency & Gamut.
Jesper
(Hey Jesper, sorry I did wrong and my answer to you is sending to Dave, but normally you can check it)
Hey D fosse !
You are the best !! When I press Q, see what happen, I've got many little part of my picture selected.
Don't understand why.. So I unselect them (by using select mode (M) and just clic anywhere) and here we are :
Now everything is clear !!!!!!
Thank you all for your advice and quick answer !
And sort for my English, hope it was suitable !
Bye, and have creative fun
Pierre.
