buenas noches
He actualizado mi ordenador y he estado instalando y desinstalando 5 veces este programa, y cada vez me lo instalaba en vasco/euskera
me gustaría resolver este problema, ya que es un programa que uso diariamente y no entiendo el euskera
un saludo
Hi Alvarol,
It seems that you are trying to download the Adobe Acrobat Reader DC application on your system.
If you are on Windows, run the cleaner tool and restart your system.
Then use this link Adobe - Adobe Acrobat Reader DC Distribution to install the latest version of the application.
Check if this helps.
Let us know if you still experience any issue.
Meenakshi
Hi Alvarol,
Meenakshi
thank you so much
You are welcome.
Let us know if you need any help.
Meenakshi
Hi.
I've had the same problem as Alvaro on two computers and your answer helped me, but using the file AcroRdrDC1800920044_es_ES.
It seems to be something wrong with the online installation.
Thank you.
Hi all,
The installation correction has been made on general Reader download page.
A correct installer for a language should now get installed. Let us know if there is an issue.
-Tariq Dar
