Please help! I have uninstalled and reinstalled InDesign CC 2018 and I still get the same result. I have also updated other Adobe programs e.g. Photoshop, Illustrator, After Effects, etc. I don't have any problems with any of the other programs. Only InDesign - I can not access master pages, or the toolbar, or edit anything in documents, it is just not responding. I have to force quit. Please advise???
Forgot to mention, when I do startup InDesign CC 2018, CPU runs between 90 -100%
Please see this link from the InDesign FAQ: CC 2018 InDesign—Don't Import previous settings and preferences
Hi Bill, thank you for your response. When I uninstalled I removed all preferences. I will also delete my InDesign caches folder to see if that works. Will keep you updated. Thank you.
Hi Bill, I uninstalled InDesign again with its preferences. I then checked and deleted both folders for
C:\Users\<USER>\AppData\Roaming\Adobe\InDesign\<Version #>\<Language> and
C:\Users\[User Name]\AppData\Local\Adobe\InDesign\Version [#]\<Language>\Cache
I then installed InDesign again. It was working fine for about 10 minutes, I was busy editing copy and it just stopped working, now it is back to not responding, with CPU for InDesign running at 60-70%
At this point it might be best for you to contact Adobe technical support. They would be more equipped with systemic recommendations than the user forum.
Please can you try this as well : Crash fixes for October 2017 (13.0) release of InDesign CC
Do you have any variable fonts installed on your system?
Did you submit the crash report? I am assuming that your InDesign crashed and not hang.
-Aman
Thank you all for the advice and support, I did contact Adobe Technical Support, the problem seemed to be caused by 3rd party fonts.
Glad it got figured out.
