Recently, I've noticed when working with an Illustrator document containing multiple text boxes, manual type manipulations are acting strange. For instance, instead of applying kerning to the type selected within a particular text box, it applies the commands to the type I worked with and/or selected prior to it (on the same page of the document.)
What's even more confusing is the copy that is being affected by the commands – (intended for type I am trying to change in a different box on the page and IS selected), isn't even selected within its particular text box???
What is this and how do I fix it???
Strange that should not happen unless maybe a plug in is conflicting, how does this look when it prints?
I did have GPU preview changing position on items that are not selected, so could possibly do this on kerning. Try Command E to turn off GPU preview.
Hi jeana,
Please try resetting preference for Illustrator.
For MAC
Close all Adobe applications.
~/Library/Caches
~/Library/Application Support/Adobe
~/Library/Preferences
Delete or rename Adobe Illustrator, com.adobe.illustrator and Adobe Illustrator 22 Settings folders.
Launch Illustrator from the creative cloud.
For Windows
Go to Locations C:\Users\user\AppData\Roaming\Adobe and.
Delete or rename Adobe Illustrator and Adobe Illustrator 22 Settings folders.
Kindly update the discussion if you need further assistance with it.
Srishti
Sorry I have not responded yet. I’ve been out of my office traveling and have not had a chance to implement the suggestions.
Thank you for following up!
ja
No worries, we are just trying to make sure these posts get updated, so the forums are a great source off information for all who come here.
When replying make sure your auto signature is off. I removed your contact information so you don't get telemarketed.
Thanks Mike!
That did help solve the problem! I appreciate the advice on how to fix.
ja
Great. For my part you are welcome.
Sad to hear though that GPU preview is having so many issues.
Hi jeana,
I would like to know if the steps suggested by above worked for you, or the issue still persists.
Srishti
