hello
how can i create a clipping mask of a picture inside a circle that the picture is blended with another image that is above it?
If i start with two images that i bland together and then i add a circle for clipping mask, only the first image clips to it.
You need to clip the first layer to the shape, then the second layer to the first layer.
Can you post a screen shot? Have you tried putting the layers in a group, then clipping the circle to the group?
hey man, I try to clip the upper two to the circle below.
Hi
In the layers panel :
1. Alt click on the border between "Layer 0" and "Rounded rectangle"
2. Alt click on the border between "Texture2" and "Layer 0"
Dave
hey davescm​, i tried with alt but it duplicate my laters and not clip them.
tomer-n wrote
hey davescm , i tried with alt but it duplicate my laters and not clip them.
Alt click on the border between two layers in the layers panel should not duplicate the layer. If you hold down Alt a little square and down arrow appears instead of the normal cursor
Then keeping Alt held down - click and the layer is clipped
Dave
thanks chuck. it worked!
