Hello,
I'm helping one of you can help... I have updated both all of my CC adobe applications to 2017. I am trying to open my .CR2 raw files from my Canon Rebel XSi. I have installed Camera Raw as well as all of the updates. Clearly I am doing something wrong, but I keep getting this message when I try to open or import images from my camera into Photoshop or Lightroom:
If this helps, this is what my .CR2 images look like in Adobe Bridge.
Thank you so much for your help!
Trevor and John,
Finally figured out what it was.... Photoshop was reading my .cr2 files from my USB as corrupt. When I imported them via the card reader, it worked fine. Bummed that it took me 3 hours to get to that point, but happy I'm there.
Thank you both for your reply,
Alicia
Hi Fly Girl
Is the Rebel XSi a newly released model? I can see an XSi from 2008 (aka EOS450) which should definitely be supported by CC2017.
Out of interest, open Photoshop and go Help > About plugin > Camera RAW which will open a window like this and show what version of ACR you have iunstalled
Raw files from the XSi should be able to be opened by Photoshop CC out of the box.
Can you upload one of the CR2 files and post a link so we can download it and open it on our computers?
Trevor and John,
Alicia
I am having a similar problem viewing CR2 files taken with either my 7D Mk2 or a 5D MK4 I have updated the elements 12 adons to version 9.8 but still get the following error message
Can anyone help as I am pulling my hair out?
Tony
I'm running CS6.
Camera RAW 9.1.1.461 is installed.
My .CR2 Canon 5D Mark IV files will not open.
Any idea how I might fix this?
Many thanks!
Denis
Cameras supported by Camera Raw
Simply put: old software cannot read Raw files from new camera without an update. In your case, there's unfortunately no update available.
You've got a couple of options:
Thanks for the reply.
I'll stick with CaptureOne.
The reason I wanted to open a file in ACR is that it has a green fringing removal slider, which C1 (stupidly) does not. (It only has purple fringing correction, separate from the CA correction.)
Green fringing (separate from any Chromatic Aberration correction) is very rare. But, I happen to have some in a file I'm working on.
Thanks again.
D.
