I am trying to follow a troubleshooting tip from another forum to address a crash issue with my Acrobat Pro. They suggest checking for updates. I try to do this and I get the following message:
Cannot connect to Adobe update server. Please verify that you are connect3ed to the internet and check for updates again. Error:1042
Obviously I am connected to the internet or I would not be able to post to this forum. Can you help ?
Hello ButterflyQueen,
As per the description above, you are getting error 1042 while updating the Acrobat Pro, Is that correct?
Please refer and try the troubleshooting steps from the following KB doc Resolve error 1402 or error 1406 when installing Acrobat or Reader Link: https://helpx.adobe.com/acrobat/kb/error-1402-error-1406-acrobat.html
Fix Windows errors that occur during Acrobat Reader update Link: https://helpx.adobe.com/in/acrobat/kb/update-errors-acrobat-reader-windows.html
Troubleshoot issues with updating Acrobat or Reader on Mac OS Link: https://helpx.adobe.com/acrobat/kb/troubleshoot-update-errors-acrobat-reader.html
You may also try to download and install the updates manually through Overview — Acrobat and Adobe Reader Release Notes Link: http://www.adobe.com/devnet-docs/acrobatetk/tools/ReleaseNotes/index.html
If the issue persists, please share the following details:
Hope this helps, and let us know how it goes.
Anand Sri.
The steps in the link provided will not work. I can not uninstall and reinstall the application on my own. When I downloaded the suite form your website and installed it on my new Mac, some of the installation flies were missing and a tech had to do a remote share, access terminal to get the product to install. Is there a link that explains this process so I can repeat it on my own? Also the steps in the link do not apply to Mac OS.
Thank you for the additional information. The above-mentioned steps are for Standalone Acrobat.
As you mentioned that you have a Mac operating system and a Creative Suite CS 6, you can use the Creative Cloud Cleaner tool uninstall the Creative Suite CS 6, and for Acrobat, you can uninstall it by running the uninstaller file from Application.
Restart the computer, and can reinstall the CS 6 which includes Acrobat from Download Adobe Creative Suite 6 applications Link: https://helpx.adobe.com/in/x-productkb/policy-pricing/cs6-product-downloads.html
For installation of CS 6 on Mac OS, you may refer to Installing Creative Suite on macOS 10.12 (Sierra) Link: https://helpx.adobe.com/creative-cloud/kb/install-creative-suite-mac-os-sierra.html
If the issue persists with Acrobat, you might have to remove the Acrobat files manually, first uninstall Acrobat, then remove the Acrobat folders from System and User Library i.e. /Library/ApplicationSupport and ~/Library/ApplicationSupport.
Restart the computer and reinstall the Suite.
Anand Sri.
To anyone that had the same problem trying to unsuccessfully update, install or register an Adobe product, after having spent days on the phone/chat with Adobe, to no avail, I was able to isolate the problem on my own. The issues exits with the DNS settings. Why no one from Adobe suggested this after telling me repeatedly to delete and reinstall the software, is beyond me. The solution really was quote simple.
DNS settings are specified in the Network window.
Example: Changing DNS server settings on Mac OS 10.5
Note: There is no support for DNS-over-TLS in the base OS. To use DNS-over-TLS requires setting up a proxy resolver that supports DNS-over-TLS. Due to the complexity of the setup we do not describe it here.
Here is the link to where this information is located: Get Started | Public DNS | Google Developers
Thanks for sharing this. If it fixes it, it seems to suggest that whoever you were using for DNS before was blocking access to Adobe's serves for some reason. This is pretty unusual, you might ask them why.
I followed the instructions, I think correctly, and it didn't work. I still get the same error message when trying to update.
