Hi
I am using Lr CC as the new editing tool to great satisfaction, however I have realised that I need to retain Lr CC Classic to keep my edits (changes on originals) and originals accessible at all times, locally. My workflow on a photoshoot involves (1) importing photos from my several cameras, (2) editing, and (2) producing the results into an album for easy sharing. Then move on to the next photoshoot. However I want to keep the first photoshoot's (retained) originals plus their edits organised and accessible locally, as I had it with Lr CC (now called Classic). How do I prepare a Collection or otherwise in LrCC containing originals plus edits, for importing into Lr CC Classic to achieve my objective as per above? Or are there better suggestions to achieve this?
Many thks!
Hover over the identity plate in LR Library (top left) and when the triangle icon appears, click to open the activity center where you can start and pause sync.
Lr CC gives the option in preferences to also store an original locally. You can nominate the Pictures folder or an external hard drive. So for all photos imported into LR CC you would have an original backed up in the cloud plus another original stored locally.
Thank you. I am aware and already using the local storage setting. My question is about retaining the edits as is done in Lr CC Classic's Catalog. Therefore, after I delete the photoshoot originals from the cloud, having stored them locally, how do I retain the editing changes to the originals for importing into Lr CC Classic (as Lr CC does not now make use of a Catalog). My objective is to be able to access a photoshoot in the future and work on an original plus its previously made editing changes - this is possible of course in Classic.
The only way to do that is to keep sync turned-on in Lr Classic. Import originals into Lr CC and they will upload to the cloud and then down to Lr Classic.
You need to be aware that the "store a copy of all originals locally" really means "store a copy of all currently uploaded originals locally", i.e. if you delete an original from the cloud, the previously stored local original is also deleted (immediately).
Then it would seem to me that Classic would be a better choice as the main program for this person's workflow.
Thanks again, also for the fast response. This could be a feasible way of working, however just to confirm: "how do I "keep sync turned-on in Lr Classic"? I located a sync reference in Edit>Preferences>Lightroom CC tab, and have specified as the location for Lightroom CC ecosystem images, the folder within which all Lighroom saved photo subfolders are located - is there any other setting I need to manage for "keeping sync on" in Lr CC Classic?
Very useful: I'll experiment with this as a way to work with Lr CC and Lr CC Classic together in order to achieve my aims. Many thanks for now
Cannot find a way to export bracketed images from LR CC to PS 2020?
