When previewing 4K video on the timeline with some effects, it takes 11-17 seconds to show the preview for one frame. We have enabled the Ray-traced - GPU setting under Preview but the systems still uses 100% CPU and 1% GPU. As far as I read up in the forums, Ray-Trace is discontinued - so this setting is useless? Does this mean that only my CPU will be used when I work in AE for preview and (as I have read) also my GPU will only be used for rendering in certain situations where the effects and codecs used are compatible with GPU rendering.
System:
CPU: Intel(R) Core(TM) i7-6900K CPU @ 3.20GHz
GPU: NVIDIA GeForce GTX 1080​
Motherboard: X99P-SLI-CF
Memory: 64GB RAM
Adobe: After Effects cc 2018
Hi wallydb,
I think you're confused. There are two GPU settings.
The one that you seem to have enabled is for the old Ray-tracer (which is obsolete).
Correct. It's all circumstantial and the usual limitations apply - a single CPU-only effect will still break GPU rendering as will several other conditions inherent to how AE works.
Mylenium
Hi wallydb,
Another setting is under File > Project Settings > Video Rendering and Effects, which has to be set to Mercury GPU Acceleration. This is what controls whether things like GPU-accelerated effects and motion blur use the GPU for rendering and previewing. Please note that previewing and rendering (is complicated) use a mix of CPU and GPU depending on what features you're using. Don't be surprised if you notice the CPU being used more than the GPU or vice-versa.
Hope this information helps.
Rameez
Thanks Myleniumand RameezKhan,
My acceleration is enabled and set on the Mercury CPU Acceleration (CUDA) - still the system is not using my GPU. The card runs beautifully in programs like Blender and Mark3D.
AE uses the GPU for very little. Other than the obsolete ray-traced renderer (which only used the GPU to create the 3d geometry - nothing else was accelerated), there are only a few effects that work on the GPU. I think the list is: Fractal Noise, Gaussian Blur, Fast Box Blur, Lumetri Color, Sharpen, Brightness and Contrast, Find Edges, Glow, Hue/Saturation, Invert, Tint, and (in some cases) the Transform effect. AE also (in some situations) uses the GPU to accelerate layer motion blur. Additionally, all the new VR effects require a GPU to render.
However, the vast majority of effects and basic video file rendering don't use the GPU. (I think it uses the GPU to debayer R3D footage too, but I don't mess with RED cameras so I've not had to worry about it.)
hi. I've done as u described, but there's an issue. AE pop-up:
but my GPU works on 0%.
any help will be great guys.))
