I am building a PC for video editings and would like to be able to use Premiere Pro. I don't expect that I will be editing in 4K but I before I purchase all of the components for the build I would like to get some feedback. I just want to make sure the program will run smoothly and I don't need to upgrade any of my components. Any feedback would be greatly appreciated.
PCPartPicker part list / Price breakdown by merchant
Even after factoring in the rebates, $1900-ish is a lot to spend on a CPU platform that's a dead end (meaning that it will not see any more new CPUs released for it), especially since it is missing a second SSD and a somewhat underqualified GPU compared to the CPU. And two hard drives put together are still a lot slower than even a single SATA SSD, let alone an m.2 NVMe SSD. Plus, AIO liquid coolers on the whole do not perform sufficiently better than a high-end air cooler to justify their extra cost. Worst of all, the X99 motherboards are still very expensive given the age and the EOL (End Of Life) status of that chipset.
I am not very good at suggesting alternatives, so I will leave that task to another forum user.
Randall
Thanks for all of the feedback.
I've got to agree with RjL. The prices are down because of it being old tech, but you are left with nowhere to go when you find it is not doing the job for you. What will you be editing? 1080? 4K? How many tracks?
I suspect that I'll be editing in 1080 for the most part. I'll have an audio track and music track, and be editing together a series of pictures and animations, with occasional effects added for most of my projects.
Your i7-6850K 6-core has a maximum turbo speed of 3.8GHz and costs you $345. If you pick the new generation i7-8700K you also get 6-cores but with the Turbo speed of 4.7GHz for a price of $420 (actual Intel Recommended Customer Price $359) but since it such a hot item there is some price gouging going on so it might pay to be patient for a short while.
You can find an X299 motherboard like the Gigabyte X299-UD4 for $240.
Get rid of that Liquid cooler and one of those hard disk drives and get modern with a second SSD drive with a M.2 PCIe x4 drive like a Samsung 960 EVO 250GB for $120. That is if your typical current project and media will fit on that size.
You just received my $100 consulting job free and this will give you a super system with long life and great performance
Since that CPU, and all of Intel's recent unlocked CPUs, do not include a "stock" air cooler at all (no matter how lousy such a cooler really is), the OP will have to buy a third-party (aftermarket) cooler for such a CPU to even be usable at all. Unfortunately, as you stated, that particular liquid cooler is just overpriced for its cooling performance.
Thanks Randall I should have added that into response. I am using the Clooer Master Hyper 212 EVO but added a second fan, now Cooler Master has the 212X with two fans for $42.
