ColdFusion Builder 2016 on Windows 10 Mapped Drives
Apr 17, 2017 Apr 17, 2017
ColdFusion Builder 2016 on Windows 7 works with mapped drives. When setting up a ColdFusion Project and/or ColdFusion Server, the browse buttons can see the mapped drives and/or one can use UNC paths which are found. On Windows 10 Pro 64-bit this is not the case. No mapped drives can be viewed and UNC paths cannot be found.
I have tried several versions of Java JRE with Eclipse Mars (4.6.2) and ColdFusion Builder 2016 plugin. And I have also tried the ColdFusion Builder 2016 stand-alone install.
Is this a bug, or can someone tell me how to make this work?
Builder
787
Aug 23, 2017 Aug 23, 2017
Hi. Were you ever able to make this work? I'm having the same issue and cannot find a solution.
Nov 16, 2017 Nov 16, 2017
I was able to setup everything with FusionDebug, which circumvents setting up ColdFusion Builder. FusionDebug is made by Intergral and is worth every penny, when using Eclipsed-base editors. I got Fusion Debug working with CommandBox too, no CF Server install is necessary. CommandBox is made by Ortus Solutions.
Nov 29, 2017 Nov 29, 2017
I had a similar problem, and found out that when running CFBuilder 2016 as a local administrator, I didn't have access to the mapped drives.  Changing to a non-administrator role restored access to them.
Good Luck...
    Dan
Documentation
