I have created a table in JSX dialog box using multiple column list as follows.
var dlg = new Window("dialog", "Animation List");
dlg.frameLocation = [100,100]; // position
dlg.size = [750, 250];
//table initailize
var w0=150, w1=150 ;
table = dlg.add ("listbox", {x:20, y:20, width:300, height:150}, undefined, { numberOfColumns:6, showHeaders:true,
columnWidths: [w0,w1],
columnTitles:["First Name", "Last Name"] });
table.add("item", "Namodaya");
table.items[0].subItems[0].text = "Balaarachchi";
dlg.show();
Output table:
But I want to edit the cells in the table. Is there any way to achieve this?
There is a Scripting forum. It only gets a half dozen posts a day, and it is not unlikely the people who follow the scripting forum also follow this one, but you'd still get a better chance of a useful reply over there.
We can move this thread to that forum if you like, or you can copy your post to a new thread over there?
Ok. I will move it photoshop scripting discussion.
Thank you very much.
Your discussion moved to Photoshop Scripting.
Ok. Thank you
As a way, define the function
table.onDoubleClick = function ()
// here place the form call to edit the current table element
Thank you for your quick response.
I tried to fix this issue with your solution. But still I couldn't understand how to edit current cell when a user clicks the cell.
Also, there has a problem how to get the current position of the cell when the table is scrollable as below.
//table initailize
for( var i = 0; i < 20 ; i++ )
table.items.subItems[0].text = "Balaarachchi";
dlg.show();
Could you please explain?
I think this is what r-bin meant.
//table initailize
table = dlg.add ("listbox", {x:20, y:20, width:700, height:150}, undefined, { numberOfColumns:6, showHeaders:true,
columnTitles:["First Name", "Last Name","Field 3","Field 4","Field 5","Field 6"] });
table.add("item", "Fred");
table.items[0].subItems[1].text = "asdfghjkl";
table.items[1].subItems[0].text = "Bloggs";
table.onDoubleClick = function(){
var w = new Window("dialog", "Edit Text");
//Add fields to suit
w.et1 = w.add("edittext");
w.et1.preferredSize=[200,20];
w.et1.text= table.selection.text;
w.et2 = w.add("edittext");
w.et2.preferredSize=[200,20];
w.et2.text = table.selection.subItems[0];
w.p = w.add("button",undefined,"Update");
w.add("button",undefined,"Cancel");
w.p.onClick=function(){
table.selection.text=w.et1.text;
table.selection.subItems[0].text = w.et2.text;
w.close(0);
w.show();
dlg.show();
Thank you.
I have tested your example. There you mean edit text in a separate window as below.
But actually, I want to edit table in itself as below. (Like Microsoft Excel)
Is there any way to do this using Photoshop scripting?
Nope.
Thanks a lot.
