My copy of Lightroom has stopped working. The program appears in the process list for a few seconds, then disappears. No splash screen. This is on Windows 10
So far I've tried:
Signing out of creative Cloud and back in again (signing out and then starting Lightroom causes it to ask about signing in, but it then falls over)
Reinstalling Lightroom
Reinstalling or repairing most of C++ redistributable - from 2015 back to 2010. I've not tackled 2008 or 2005 because there are 11 bits of 2008 and 9 of 2005 and I'm worried I'll break something else if I uninstall any of it.
The application error log gives the following:
Faulting application name: lightroom.exe, version: 6.9.0.10, time stamp: 0x58b68ac4
Faulting module name: ucrtbase.dll, version: 10.0.14393.0, time stamp: 0x578997b5
Exception code: 0xc0000409
Fault offset: 0x000000000006ea1e
Faulting process ID: 0x22ec
Faulting application start time: 0x01d2b1754ab25e47
Faulting application path: C:\Program Files\Adobe\Adobe Lightroom\lightroom.exe
Faulting module path: C:\WINDOWS\System32\ucrtbase.dll
Report ID: cd35fb06-5cd0-45b3-a4b9-6b739539c2b4
Any suggestions what to try next?
Solved. Following 3 hours of effort from Adobe support, we found a problem with AppData\Local\Lightroom. Deleted that, it all took off.
Try resetting the LR preferences
https://www.lightroomqueen.com/articles-page/how-do-i-reset-lightrooms-preferences/
I have the same issue. Preferences were reset.
It only happens when the Develop module opens. I have Photoshop CC installed as well and this is the first time I have tried opening Lightroom since the last Photoshop update.
I also have same issues. When I use the Develop module, LR is closed.
Does anyone know hot to fix it?
Found the cause of my problem.
Nvidia Drivers version 381.65 are not compatible.
went back to 378.92 and all is working again.
I'm using onboard graphics, so not my problem, glad yours is working though.
I'm not sure what you mean about 'when the develop module opens' Sounds like a different problem.
I've found the error logfile for mine; here's the end of it:
LoadedModule[111]=C:\Program Files\Adobe\Adobe Lightroom\video_toolkit.dll
LoadedModule[112]=C:\Program Files\Adobe\Adobe Lightroom\catalog_converters.dll
LoadedModule[113]=C:\Program Files\Adobe\Adobe Lightroom\Import.lrmodule
State[0].Key=Transport.DoneStage1
State[0].Value=1
FriendlyEventName=Stopped working
ConsentKey=BEX64
AppName=Adobe Photoshop Lightroom
AppPath=C:\Program Files\Adobe\Adobe Lightroom\lightroom.exe
NsPartner=windows
NsGroup=windows8
ApplicationIdentity=FC8CF5C4BEA53D79D26B756A4709C536
MetadataHash=-1316076791
I like the 'friendly event name'!
Update, I've tried renaming the catalog file. Lightroom notices that it isn't there, so I tell it to use a default one, then it falls over, same fault in the log
New version of Lightroom available today. Sadly hasn't fixed the problem.
Sadly not, though it did ask to reset the preferences, then fell over.
Hat bei mir leider nicht funktioniert
Did not work for me
