Following the most recent Windows update, I haven't been able to get Photoshop to work properly on my graphic tablet. Whenever I move the he box beneath the status bar stretches up to the bottom of the canvas, and the main part of the screen won't show anything that I draw. The layer preview will, however, so I know that the screen isn't frozen. Clicking on anything else will work too, it just doesn't show anything that I draw. I also tried experimenting in a different program, so as far as I can tell this is a Photoshop-specific issue.
Over the past 3-4 hours, I have tried:
I'm really not even sure what else to try at this point. The tablet itself (a Parblo Coast10) seems to be in working order, so as far as I can tell the problem is with either Photoshop itself or the latest Windows update.
Has anyone else had this problem, and if so were you able to fix it? Is it more likely to be an issue with Photoshop, or with the Windows update?
You might try a preference reset (not always cleared during uninstall).
Win: Press and hold Ctrl+Alt+Shift immediately after initiating Photoshop's startup. A box will appear asking if you want to continue with the reset, select "yes." If you don't see this, you weren't fast enough...Try again.
Mac: Press and hold Cmd+Opt+Shift then start Photoshop. A box will appear, asking if you want to continue with the reset, select "yes."
Also go to Edit>Preferences>Performance and uncheck “Use Grapics Proces
...Copy link to clipboard
Also go to Edit>Preferences>Performance and uncheck “Use Grapics Processor”...Restart Photoshop
Yes, I think that fixed it! I do have to go re-do my settings now, but it appears to be working perfectly now!
That’s great!
