invoking menu - language
Guide ,
Feb 02, 2017 Feb 02, 2017
Hello,
Does invoking a menu with the menu string work in any language? Example.
$ID/Override All Master Page Items
P.
Scripting
5.5K
Community Expert , Feb 03, 2017 Feb 03, 2017
I should have added:
It should work as long as you provide the locale-independent form of the string.
Sometimes simply adding $ID/ in front of the English menu name does not work or is not enough.
Better look for the title string of a menu and check with:
app.findKeyStrings("menu-title-name");
for the "universal" form(s) of the string.
Uwe
Hi Pickory,
it should, if the menu is available in the situation you want to use it.
E.g "Override All Master Page Items" is not available if no document is open.
See for example:
var menuAction = app.menuActions.itemByName("$ID/Override All Master Page Items");
for(x in menuAction)
    $.writeln(x+"\t"+menuAction);
// CASE 1 No document open with my German InDesign
    name    Alle Musterseitenobjekte übergehen
    title    Alle Musterseitenobjekte übergehen
    area    Bedienfeldmenüs:Seiten
    enabled    false
    checked    false
    id    6164
    label
    isValid    true
    parent    [object Application]
    index    101
    properties    [object Object]
    events    [object Events]
    eventListeners    [object EventListeners]
    isValid    true
// CASE 2 Document open with my German InDesign.
    enabled    true
    checked    false
    id    6164
    label
    isValid    true
    index    101
    isValid    true
So before using it you could look after the value of property enabled.
Maybe also isValid if you are not sure if a specific InDesign version does provide the menu.
if(menuAction.enabled){menuAction.invoke()};
( Just for lurkers: InDesign Server does not support menuActions )
Uwe
Guide ,
I hope you asking the menu action work in all scripting language?
Uwe
Jun 08, 2017 Jun 08, 2017
Hi, I have some trouble trying to use universal menu strings:
Some confrere submitted me a script idea, showing me a manual trick that he had designed to selectively get rid of specific unwanted style replacements in paragraphs while preserving other replacements:
http://robinfredericf.free.fr/misc/wadym-s_Idea.avi.mp4
http://robinfredericf.free.fr/misc/wadym-s_idea.png
I was interested in automating it in a script but his method uses the command "Redefine style" that doesn't exists in the InDesigns ExtendScript API, so I tried to «invoke()» it, following explanations that I read on adobe forum topics such as
https://forums.adobe.com/thread/1961958
http://kasyan.ho.com.ua/open_menu_item.html
https://forums.adobe.com/thread/892886
To get the required command to redefine a paragraph style from the selection, in a international reliable way, I decided at once to avoid to get the menuAction by its id or index because it seemed hazardous, those numbers could be assigned to totally different actions in different InDesign version, so i tried:
var redefineParagraphStyle = app.menus.item('$ID/ParaStylePanelPopup').menuItems.item('$ID/Redefine Style');
redefineParagraphStyle.associatedMenuAction.invoke();
[including jsx and demo idml file:]
http://robinfredericf.free.fr/misc/wadyms-paragraphstyle-trick_indd002.zip
http://robinfredericf.free.fr/misc/wadyms-paragraphstyle-trick_indd002-en.zip
I expected that the use of "$ID/" english strings would prevent the localization problems but unfortunately I was surprised when my colleague told me that he got the error «ReferenceError: Object is invalid»
So then I tried:
var redefineParagraphStyle = app.menus.item('$ID/ParaStylePanelPopup').menuItems.item('$ID/RedefineStyle');
var redefineParagraphStyle = app.menus.item('$ID/ParaStylePanelPopup').menuItems.itemByID(8458);
var redefineParagraphStyle = app.menus[113].menuItems[3];
http://robinfredericf.free.fr/misc/wadyms-paragraphstyle-trick_indd002a.zip
All methods worked on my side, tested on French localized versions of InDesign CS5 & CC 2015.4 under MacOSX 10.10.5 & Windows 7
But still the same "Object is invalid" error on my Ukrainian colleague's side, who tested the scripts on Russian localized versions of CS5.5 &  CC 2015.2 (11.2.0.100х64) under Windows 7.
People's Champ ,
I haven't tested anything, but IIRC some menu items are only valid when the relevant panel is open. So if the paragraph styles panel is closed on your friend's computer, he may get an error.
Ariel
Hi Ariel,
in this case the associatedMenuAction should also work, if the panel is not open.
However it can only work, if it is enabled.
And it is only enabled if:
1. Text is selected
2. Text is showing overrides on the applied paragraph style
Uwe
People's Champ ,
1. Text is selected
Okay, sounds right! I didn't go into the specific details of the case as you have (thanks for that!) -- but the principle is important: There is such a thing as a menuAction not being enabled depending on the UI configuration (either a closed panel, or as you rightly point out in this case, no text selected, etc.). So this could be Robin's problem.
Ariel
Some other details:
// My German string for "Redefine Style":
var localeKeyString = "Format neu definieren";
var foundKeyStrings = app.findKeyStrings(localeKeyString);
    $ID/Redefine Style
    $ID/RedefineStyle
    $ID/RedefineObjectStyles
    $ID/ObjStylesContextRedefine
// My German InDesign CS6 lists 9 entries of a menu action named "$ID/Redefine Style".
// The same 9 entries are also listed with: "$ID/RedefineStyle", "$ID/RedefineObjectStyles" and "$ID/ObjStylesContextRedefine"
// Results listed below when a document is open and nothing is selected:
var menuActions = app.menuActions.itemByName( foundKeyStrings[0] ).getElements();
for(var n=0;n<menuActions.length;n++)
    $.writeln(menuActions.enabled+"\t"+"\t"+menuActions.id+"\t"+menuActions.area+"\t"+menuActions.title);
    false        8458    Bedienfeldmenüs:Absatzformate    Format neu definieren
    false        8459    Bedienfeldmenüs:Zeichenformate    Format neu definieren
    false        8486    Bedienfeldmenüs:Absatzformate    Format neu definieren
    true        113158    Bedienfeldmenüs:Objektformate    Format neu definieren
    false        113176    Bedienfeldmenüs:Objektformate    Format neu definieren
    false        132102    Bedienfeldmenüs:Tabellenformate    Format neu definieren
    false        132126    Bedienfeldmenüs:Zellenformate    Format neu definieren
    false        132151    Bedienfeldmenüs:Tabellenformate    Format neu definieren
    false        132152    Bedienfeldmenüs:Zellenformate    Format neu definieren
    Bedienfeldmenüs > panel menus
    Format neu definieren > Redefine Style
    Absatzformate > paragraph styles
    Zeichenformate > character styles
    Objektformate > object styles
    Tabellenformate > table styles
    Zellenformate > cell styles
Hope, that helps…
Uwe
Jun 09, 2017 Jun 09, 2017
On my side it appears to work as well when the paragraph styles panel is closed.
Nov 21, 2017 Nov 21, 2017
Hi Robin,
didn't you post something yesterday?
How did it go without using doScript() ?
Uwe
Nov 23, 2017 Nov 23, 2017
So we tried without doScript: http://robinfredericf.free.fr/misc/wadyms-paragraphstyle-trick_indd003a.zip
// indd002-MinimumVersion-2.jsx
#target "InDesign";
#targetengine reformatToAppliedStyle
reformatToAppliedStyle();
function reformatToAppliedStyle()
    if(app.documents.length == 0){ return; } // Do we need an alert here? No.
    if(app.selection.length != 1){ return; } // Do we need an alert here? No.
    if(!app.selection[0].hasOwnProperty("baselineShift"))
    { alert("Error: No text selected."); return; }
    if(app.selection[0].styleOverridden == false)
    { alert("Error: No style override detected."); return; }
    var menuItem = app.menus.item("$ID/ParaStylePanelPopup").menuItems.item("$ID/Redefine Style");
    if(menuItem.isValid == false)
    { alert("Error: menuItem Redefine Style cannot be found."); return; }
    if(menuItem.enabled == false)
    { alert("Error: menuItem Redefine Style is not enabled."); return; }
    var myStyle = app.activeDocument.selection[0].insertionPoints[0].appliedParagraphStyle;
        // [ No Paragraph Style ] used.
        NOTE: The following if statement should never be executed
        if [ No Paragraph Style ] is really used on selected text,
        because "Redefine Style" is never enabled with [ No Paragraph Style ]
        and we already have an error condition for that case.
        Nevertheless:
        You cannot duplicate [ No Paragraph Style ]
    if(myStyle.index == 0)
    { alert("Error: No custom paragraph style applied: [ No Paragraph Style ]"); return; }
    // [ Basic Paragraph Style ] used.
    // You can duplicate that style, but you cannot remove the original.
    // You cannot rename the duplicate to that style.
    if(myStyle.index == 1)
    { alert("Error: No custom paragraph style applied: [ Basic Paragraph Style ]"); return; }
    // FWIW: Styles cannot be named with [ or ] in their names.
    // [ and ] are restricted to the names of the base styles.
    // Maybe there are other special characters that are not working?!
    var myStyleName = myStyle.name;
    var myStyleCopy = myStyle.duplicate();
    menuItem.associatedMenuAction.invoke();
    myStyle.remove(myStyleCopy);
    myStyleCopy.name = myStyleName;
Result:
So it says:
JavaScript Ошибка! = JavaScript Error!
Номер ошибки = Error number: 45
Сообщение об ошибке = Error report: Object is invalid
Engine: reformatToAppliedStyle
Файл = File: C:\Users\Вадим\AppData\Roaming\Adobe\InDesign\Version 11.0
\ru_RU\Scripts\Scripts Panel\wadyms-paragraphstyle-trick_indd003a.jsx
Строка = Line: 20
Источник = Source:    var menuItem = app.menus.item
Guru ,
Dec 17, 2017 Dec 17, 2017
Hi Frédéric,
I spent a couple of hours on this but now I think I know why Wadym encounters the problem.
This is a bug in Russian locale. (so far I tested it only in CC 2015: the same version as Wadym has).
I tried to reference the menu item by index -- in my copy it's 97 -- and it returned quite a strange result:
  • The isValid property of menuItem is false, but menuItemIsValid is true despite the fact it references the same above mentioned  property.
  • The name and title are strange: contain inch marks which is not allowed here I guess.
  • There are no other properties
var menuItem = app.menus.itemByName("$ID/ParaStylePanelPopup");
Doesn't return a valid reference:
In English locale everything is OK:
I tested it with some other locales -- Arabic, Chinese, Spanish, Polish -- and it works OK, so it happens only in Russian.
I suggest Wadym and everybody with Russian Indy not to use the menu item reference but use menuActions.itemByID instead.
Here's my version:
#target "InDesign";
function reformatToAppliedStyle() {
    try {
        Nevertheless:
        app.menuActions.itemByID(8458).invoke();
    catch(err) {
        alert(err.message + ", line: " + err.line);
Kasyan
Dec 19, 2017 Dec 19, 2017
Jan 21, 2018 Jan 21, 2018
I owe you all an answer, I was very busy since then (happy new year by the way!) so yes — using menuActions.itemByID instead of menu item reference does make this script finally working on all Wadym's InDesign localized versions as he confirmed to me on 3rd of January. My first question (or my primary goal, as we don't use universal menu strings anymore) is basically solved since the manual trick is now successfully scripted but I am still working to improve it for some specific cases that he submitted me, where some unwanted replacement are not suppressed neither with the manual method nor with its equivalent scripted version, or where it suppresses replacements that should be preserved such as a "bold" attribute applied using a character style causing the overridden "bold" attributes disappear elsewhere.
Mar 14, 2018 Mar 14, 2018
This improved version http://robinfredericf.free.fr/misc/wadyms-paragraphstyle-trick_indd009.zip tested by Wadym for about a month appears to work even on those specific cases (showed in the included test file). I would be happy to thank you all for help in the article or at least in the source code of the script when publishing it on Scriptopedia.org 🙂 The current version enables as well to work on the [Basic Paragraph] style but I think I won’t boast too much about it because I had to create an alternate maybe less reliable method for the [Basic Paragraph] so I think I will rather let the most curious users discover this possibility as an undocumented feature.
try this:
var menuItem =
app.menus.itemByName("$ID/ParaStylePanelPopup").
menuItems.itemByName("$ID/Redefine Style");
if(menuItem.enabled)
Uwe
Thank you to answer so quickly,
Checking if the menuItem is enabled before invoking it is basically what I already did in my first attempt http://robinfredericf.free.fr/misc/wadyms-paragraphstyle-trick_indd002.zip but I copied on this post only the most important line, assuming that people would check the link to see all the script, so if not the case here it is:
#target "InDesign";
$.localize = true;
$.locale = null;
//$.locale = "en";
function main() {
    //var redefineParagraphStyle = app.menuActions.itemByID(132102);
    /* « redefineParagraphStyle.invoke() » => Error « Script not activated. » */
    /* cf. https://forums.adobe.com/thread/1961958 */
    //var redefineParagraphStyle = app.menus[113].menuItems[3];
    /* Marche dans InDesign CC 2015 mais dangereux car peut correspondre à une toute autre commande dans une autre version. */
    /* cf. http://kasyan.ho.com.ua/open_menu_item.html https://forums.adobe.com/thread/892886 */
    if (! redefineParagraphStyle.enabled) { throw new Error({
            en: "This script is intended to be used when selecting (or placing the cursor in) some text that has a paragraph style applied "
                +"and some unwanted overriden attributes that will be reverted to the style's values "
                +"for all occurrences where the same overrides affect the same style in the document.",
            fr: "The script est prévu pour être utilisé en sélectionnant (ou plaçant le curseur dans) du texte ayant un style de paragraphe appliqué "
                +"et certains attributs affectés par des remplacements indésirables qui seront rétablis à la valeur du style "
                +"pour toutes les occurrences où les mêmes remplacements affectent le même style dans le document."
try {
    app.doScript(
        function() { main(); },
        ScriptLanguage.JAVASCRIPT,
        undefined,
        UndoModes.ENTIRE_SCRIPT,
        File($.fileName).name
} catch(e) { alert(e); }
and I also already tried app.findKeyStrings() to get other variant of the locale-independent string, so in http://robinfredericf.free.fr/misc/wadyms-paragraphstyle-trick_indd002a.zip I tried to replace '$ID/Redefine Style' with '$ID/RedefineStyle' — expecting that it might be better without space.
I also presume my colleague knows that he has to select some text that is showing overrides on the applied paragraph style, before running the script, because it was first his own idea and because I explained how to use the script on the demo idml file included with the jsx in the zip. From that screenshot he sent me he seems to be correctly attempting to use the script when the error message occurs:
I wonder if other users would get the same error when trying the script wadyms-paragraphstyle-trick_indd002.jsx on the document wadyms-paragraphstyle-trick_indd002.idml, for example on a German InDesign version.
Jun 10, 2017 Jun 10, 2017
Hi Frédéric,
tested your script:
on:
Same selection as shown in your screenshot with the error message.
No problem with my German versions of InDesign CS5.5 and CC on OSX.
The script ran as intended.
I observed one difference in error handling of CS5.5 and CC v 9.3.0.
You do not ask if a document is open or if text is selected.
If you provoke such an error CS5.5 is alerting a simple: "undefined" statement.
And that's ok, I think, because you wrapped the try/catch around the doScript statement and did no error handling on the two cases I mentioned. Surprisingly InDesign CC is alerting your full error message regardless of the individual error caught. Just picking up the message…
For individual error handling I'd suggest something like that:
app.doScript
    reformatToAppliedStyle,
    undefined,
    "Script | Undo Action"
    if(app.documents.length == 0){ return }; // Do we need an alert here? No.
    if(app.selection.length != 1){return}; // Do we need an alert here? No.
    { alert("Error: No text selected."); return };
    { alert("Error: menuItem Redefine Style cannot be found."); return };
    { alert("Error: menuItem Redefine Style is not enabled."); return };
        Nevertheless:
    { alert("Error: No custom paragraph style applied: [ No Paragraph Style ]"); return };
    { alert("Error: No custom paragraph style applied: [ Basic Paragraph Style ]"); return };
Uwe
Jun 11, 2017 Jun 11, 2017
Additionally you could do a test for overrides in selected text after line 22:
{ alert("Error: No style override detected."); return };
Uwe
Thank you both for your suggestions, so June the 12th I uploaded this http://robinfredericf.free.fr/misc/wadyms-paragraphstyle-trick_indd003.zip but then there was the summer holidays and after them we were too busy. Recently I also tried something else to avoid the use of menu item invocation http://robinfredericf.free.fr/misc/wadyms-paragraphstyle-trick_indd006.zip attempting to emulate the "Redefine Style" command using something like that:
myStyle.properties = app.activeDocument.selection[0].insertionPoints[0].properties;
It works on InDesign CC but does nothing on InDesign CS5. Moreover it seems quite hazardous because it is not really equivalent to the original manual trick (I had to surround it by additional code intended to avoid the redefinition to include attributes from character styles, nested styles, grep styles…).
So I rather suggested my colleague to try the previous wadyms-paragraphstyle-trick_indd003.jsx version:
#target "InDesign";
app.doScript
    undefined,
        Nevertheless:
Expecting that your in-depth error handling would enable us to dig what’s wrong with his localized InDesign versions.  But he gets those errors:
wadyms-paragraphstyle-trick_indd003_error-cc.jpgwadyms-paragraphstyle-trick_indd003_error-cs5-5.jpg
So both CC and CS5.5 screenshots basically say the same thing:
Сообщение об ошибке = Error report: Недопустимый объект = Object is invalid
Файл = File: C:\Users\Вадим\AppData\Roaming\Adobe\InDesign\Version 11.0/7.5\ru_RU\Scripts\Scripts Panel\wadyms-paragraphstyle-trick_indd003.jsx
Строка = Line: 7
Источник = Source: (
He seems to have problems with the doScript() method, so I will try without it…
