I use LR and PS CC on desktop. I wanted to download LR CC for ipad. I have a Air Pro 2. Can't find the place where to download, no help on Adobe site. Is there a URL where to find the app just for ipad? I tried Apple store, the app says not compatible with my ipad?
It looks like that you have tried to download the iPhone version. Just double check the app store filter and set this iPad Only .
Hope this helps.
Guido
All apps for the iPad (normal and Pro) are only available from one place: the Apple App Store for iOS devices.
On your iPad, touch the App Store icon and search for Lightroom CC for iPad. Download it from there.
Hope this helps.
Guido
OK Guido, thank you for your guidance. I'll do that.
Thank you John, I'll do that.
Thats a little ambiguous. If you have an iPad Air 2, LR for iPad may not work unless you’re running iOS 10 or later. If you have an iPad Pro, it shouldn’t be a problem. There isn’t an “Air Pro.”
If you have a Pro, then Guido is probably spot on.
Mike
Thank you Mike for the clarification. It's an Air 2.
I run it with iOS 10, and I am now updating to iOS 11.
I'll follow Guido's guidance. Hopefully, that'll work.
Thanks again.Phil
