If I use Nik collection as a plug in for say, pro contrast or glamour glow, when I click okay, Photoshop crashes.
Any ideas please?
Hi all,
Nik collection plug-ins by Google stopped official support after Photoshop CC 2015. As Photoshop has changed without updates to the plugins, we're seeing more and reports of the plug-ins crashing or freezing Photoshop.
More info on current supported Photoshop versions on Google's page here: Google Nik Collection
As of late, DxO has picked up the plug-in collection and will resume development. Mid-2018 seems to be the timeframe they're looking to release a more compatible version of the col
...Copy link to clipboard
Hi YoDude,
Which version of Photoshop are you using?
Could you please refer this documentation Crashes - Nik Collection Help and let us know if that helps?
Akash
No it doesn't help Akash, it's when I click okay noy open Nik does it crash
Try uninstalling photoshop and reinstalling it. Then add the plugin back.
I'm just in the process of reinstalling Nik Col. Let you know how things go.
That didn't work, tried using pro contrast and within a second or two of me hitting okay, PS crashed
I'm now uninstalling Photoshop 2018
I have the same exact problem... just started. Tried everything, including what worked months ago... no deal. Crashes.
No success. I've reinstalled Photoshop and Nik Collection and am still having the same problem.
I try using Nik C for any of the filters and as soon as I click okay, Photoshop dies on me and everything is lost.
So what happens now please?
Could you please try restoring Photoshop preferences and check if that helps? Refer Preferences in Photoshop
If the issue persists, please provide the crash report from the crash event so that we can diagnose it.
Akash
Sorry but I am not computer savvy, what do you mean restore preferences, I don't think I have ever changed any
Sorry but where do I find a crash log? When it shuts down, there is nothing, no report to send.
To restore preferences quickly using a keyboard shortcut:
Press and hold Alt+Control+Shift (Windows) or Option+Command+Shift (Mac OS) as you start Photoshop. You will be prompted to delete the current settings.Select "Yes"
The new preferences files are created the next time you start Photoshop.
Note: Using the keyboard shortcut, preference files for custom shortcuts, workspaces, and color settings will also be reset to default.
~Akash
photoshop 2020 crashing when launching Nik collection filters
mac mojave 10.14, photoshop 2020, nik collection 2.3
Two issues...I need Nik Collections to work!
-i open document, launch silver efex pro and photoshop crashes.
-i removed all Nik collection files automactically and through uninstaller and yet they remain in photoshop filter directory?
Help!
Just tried that and all it asks me to do is ... delete photoshop settings file. I clicked Yes, tried again but it made no difference, same problem
I do not get a crash report when it crashes, PS simply hsuts down in a nano second
Had the same problem. Solved it by changing the settings "After clicking OK" -> "Apply the filtered effect to the current layer".
Nic, just had a look, do you mean after you press OK on thge Nik filter, you then press"Apply the filtered effect to the current layer"?
If you do, then I can't do that as within a nano second Photoshop shuts down with no warning, I can do nothing once hitting OK.
Okay nec, I'll give it a go.
Thanks.
Is there nothing that can be done!?
I can't produce a crash report .
I've unistalled Photoshop and Nik and reinstalled but no better.
I click Okay to accept the filter, say Pro Contrast, I get the moving bar showing it is applying the filter and then PS after a second or two crashes and takes all the images with it.
Hi all,
As of late, DxO has picked up the plug-in collection and will resume development. Mid-2018 seems to be the timeframe they're looking to release a more compatible version of the collection.
You can request to be notified of any updates by them here: Homepage - Nik Collection by DxO
Pete
If you go to settings, when the filter is open, before you click ok and “apply the filtered effect to current layer”so the filter doesn’t create a separate layer, photoshop doesn’t crash. Also unlock the image before opening the filter, so the layer is “layer 0”
This totally works. Thank you for the clear instructions. Whew!
When Nik is open, click on "Settings" button. Then select "After Clicking OK" and choose "apply the filtered effect to the current layer". So glad to have Nik working again!!
