Bonjour,
Je n'arrive pas à ouvrir les fichiers pdf dans ps cc du travail. Il m'affiche toujours "Impossible d'effectuer cette opération en raison d'une erreur de disque." Je sais pourtant que c'est possible car les fichiers pdf s'ouvrent sans problème sur mon ps cc privé.
Please Adobe Forum, help me?
Merci
P.S : Mon post au travail est un imac et mon ps privé est installé sur un macbook pro.
Hello
I can't open the pdf files in ps work cc. It always shows me "Cannot perform this operation because of a disk error." I know it's possible because pdf files open without problem on my cc ps private.
Thank you
PS: My post at work is an imac and my private ps is installed on a macbook pro.
How was the pdf created (with which application for example)?
What have you done for trouble-shooting so far?
Restoring Preferences after making sure all customized presets like Act
...Copy link to clipboard
Hello
Thank you
Restoring Preferences after making sure all customized presets like Actions, Patterns, Brushes etc. have been saved might be a good starting point:
https://helpx.adobe.com/photoshop/kb/basic-trouble-shooting-steps.html
Can you place the pdf in a new document (File > Place Embedded)?
Thanks for the quick answer.
I can open the pdf in ps cs6, on my co-worker Mac, in illustrator cc and in Acrobat Pro. Only on my computer it didn't work.
From your trouble-shooting instruction I have reset the preferences of ps cc and it works:) But I can't identifiy what is the exactly the problem and therefor I should entirely re-configurate my photoshop.
Any ideas of what it could more precisely be?
Thanks for the help
Unfortunately no.
As I mentioned you could try to work around the issue by placing the file instead of opening/converting it if all else fails.
