Get Selected Item(s) in Project Panel
Mar 14, 2017 Mar 14, 2017
Going through the examples and documentation, I couldn't find a function or value to tell if a folder or footage item is selected or access that item in the Project Panel of Premiere Pro. Closest thing I found was .select() which only selects the item you have coded. Has anyone had any success with this? Thanks!
SDK
3.2K
Adobe Employee , Nov 20, 2017 Nov 20, 2017
While PProPanel now shows how to get a message (and all selected projectItems) every time the project selection changes, getting and setting selection are not yet available.
Adobe Employee ,
Mar 21, 2017 Mar 21, 2017
There is no API around project selections, in current versions of PPro. It's a highly-requested feature.
Nov 16, 2017 Nov 16, 2017
Any updates on this feature implementation? Thanks!
Adobe Employee ,
Thanks Bruce Bullis​ this definitely helps! Just to confirm, the app.bind("onSourceClipSelectedInProjectPanel", function()) event is only available in PPRO CC 2018 yea?
Adobe Employee ,
Correct.
And from what I can tell, there's no way to know if nothing is selected in the project panel correct?
I'm basically assigning selected values to a variable to access them whenever I need to, but it seems that the "onSourceClipSelectedInProjectPanel" event doesn't update if everything is deselected. Thanks!
Also, I'm only getting up to 2 project item (arguments) at a time from app.bind("onSourceClipSelectedInProjectPanel", function()). Is that a bug, or am I missing something?
Enthusiast ,
Nov 22, 2017 Nov 22, 2017
The TrackItem type has an isSelected field. You could easily search the timeline when you receive your callbacks for all items where that field returns true to build your own selection set...
sberic​ I haven't used TrackItems before. Do they correlate to objects selected in the Project Panel or Timeline? I'm trying to get objects selected in the Project Panel.
Adobe Employee ,
trackItems = things on a track, in a sequence.
That's what I assumed. I'm noticing there's a selected metadata column in the project panel now, but the metadata doesn't seem to update when an item is selected. Is this a way I can access selected items? Bruce Bullis​Screen Shot 2017-11-22 at 9.42.55 AM.png
Adobe Employee ,
Not intentionally, no.
We're Working On Itâ„¢.
Okay good to know, thanks for the heads up!
Enthusiast ,
justin2taylor  wrote
sberic  I haven't used TrackItems before. Do they correlate to objects selected in the Project Panel or Timeline? I'm trying to get objects selected in the Project Panel.
Whoops! Right, my bad. Those are Timeline APIs, not Project library.
This sounds like it's either a bug or an implementation detail. Perhaps it's related to "itemDeselected" and "itemSelected" parameters? If you select multiple at once (select one and then hold shift while clicking one several items lower), do you get multiple callbacks?
Bruce Bullis​, I checked the What's New in 12.0? list of changes but did not see this API mentioned. Bug? Missed addition?
Sep 07, 2022 Sep 07, 2022
Almost 6 years later... Are you still working on it? How to select a project item?
