I'm having trouble with Acrobat's Sanitize Document function.
Each time I use it and Save the changes by overwriting the sanitized document, the document's resolution is lowered to 150 DPI from 300 DPI.
I don't Save as Optimized so I have no clue why the document's resolution is being lowered. Is Sanitize Document somehow connected to Optimize PDF?
Where do I disable the change of resolution?
Mark
Hi fbm29754842,
We apologize for the issue you are facing.
Could you please share the file and the output with us.
Sending you a private message with the email address you need to send the files at.
Thank you for your patience!
Girija
I am having the same issue as TS.
Any solutions?
Thank you,
Simon
Hi Simon,
This behavior is As-Designed.
During the sanitization process, every PDPage having images is rasterized and this is done at a fixed dpi of 144.
However, I have reported this as a change request to the concerned team. We will inform you if there is a workaround or change in the same.
Girija
Hi Girija,
Any news on this As-Designed deficiency? I would like to keep sanitized documents at 300ppi, otherwise even text looks and prints terrible at 144ppi. Please advise.
Val
Are you also using Acrobat XI still?
No, I'm on Acrobat Pro DC.
