This has only just started happening and I have no idea why.
I can open an image and it appears as a locked background (never even noticed the lock before now)
When I try to drag and drop another image onto it as a layer it just opens up as a fresh new background image and only the latest one appears in the layers palette.
I can still see the other in the workspace and if I click on the original then it is the only one that appears in the palette
I have reset preferences but this has made no difference.
Any help is appreciated
How exactly? Do you drag it into the Canvas?
You could use File > Place … instead.
That seems to be a work around
Originally it would allow the second image to appear in the canvas and then I could select an area within that second image and then paste it onto the original/background
It does not allow that any more
If you want to have several images as separate windows you could chose Standard Screen Mode (F) and turn off tabbing and docking (Photoshop > Preferences > Workspace > …).
Thanks again but it's not that quite what I was looking to achieve. Until yesterday I opened one image and when I simply dragged a second image onto the same canvas it simply created a new layer.
Your earlier suggestion works but I would love to find out what has changed or what I have done to prevent this happening since yesterday.
Thanks again
