iMac 27inch 5k 2017
radeon pro 570 4gb is in use
In photohop, change the picture to cmyk mode, and then select liquify by rectangular marquee tool.
The brush will not click properly and will be clicked differently.
I tested it in various situations.
Photoshop cc - Latest Version, 2015
osx - Sierra, High Sierra
iMac 27inch 5k 2017, Macbookpro 13inch 2016 late
I checked all of them in the initialized state,
The same symptoms occur.
Thank you for your help.
iMac 27inch 5k 2017
radeon pro 570 4gb 사용중입니다
photohop에서 그림을 cmyk 모드로 변경 후 rectangular marquee tool 로 부분 선택하여 liquify를 하면
브러시가 정상적으로 클릭이 안되고 어긋나게 클릭이 됩니다.
여러가지 상황에서 테스트해보았습니다.
포토샵 - 최신 버전, 2015
osx - 시에라, 하이시에라
iMac 27inch 5k 2017 , Macbookpro 13inch 2016 late
모두 초기화 된 상태에서 확인해보았지만,
동일 증상이 생깁니다.
해결방법 부탁드립니다.
I would think many thins in liquify would not work when your document is in CMYK mode.
Thing like Face control require GPU support. On windows in CMYK Mode selection seems to work with Liquify though.
