为什么将三个通道之一作为选区选择会选择整个画布?
Hi LimboN,
Could you please let us know which version of Photoshop are you using & on which operating system?
Sahil
Operating System: Windows 10 家庭版 64-bit (10.0, Build 15063) (15063.rs2_release.170317-1834)
photoshop: 19.0 20171103.r.190 2017/11/03: 1143799 x64
为什么不是选中图形而是整个画布?
还有请看看该问题显示重叠
Is this issue happening with multiple files or only with one specific file? could you try resetting the preferences of Photoshop & let us know if it helps: https://helpx.adobe.com/photoshop/using/preferences.html
不是首选项的问题,因为CS6也是这样,透明图形都会发生这种问题;
还有使用滤镜里的彩色半调怎么会这样
使用后
使用前
Could you please share a screen shot of your layers panel, also please let us know is this happening with one specific file or multiple files?
before
options
after
Thanks for sharing some screenshots, was this issue happening when you were using Photoshop before the update?
是的,其他文件也会出现该问题~
用直线工具绘制好的直线段无法更改粗细,需要先更改粗细值在绘制直线~
