Hello All,
I recently updated to Photoshop CC 2018 and I've noticed that when I use the Pen or Ellipse tools set to Shape, no fill, and a stroke of some size (usually around a few pixels) they are very, very slow to update. For example, if I draw out an ellipse as a shape, no fill, and a one pixel stroke, I see the spinning balls for a few seconds before the stroked ellipse is seen on the canvas. Working with these tools were pretty much instantaneous in previous versions. I don't think it is my PC as I have a pretty hefty workstation:
CPU: Intel i7 5820K 3.30 GHz
RAM: 128 GB
Video: Nvidia GTX 1070 (8 GB)
Windows 10
If others are getting a fast response with the pen and ellipse tools, I would appreciate any help so I can speed up these tools as I work.
Thanks in advance.
Post your menu Help>System Info.
I only tried the Ellipse tool shape mode new shape layers and combined shape layer. All I saw was a short delay with the fill and stroke. I would not call it slow. More a very slight lag.
Here is my system info:
Adobe Photoshop Version: 19.0 20171103.r.190 2017/11/03: 1143799 x64
Number of Launches: 7
Operating System: Windows 10 64-bit
Version: 10 or greater 10.0.16299.15
System architecture: Intel CPU Family:6, Model:15, Stepping:2 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
Physical processor count: 6
Logical processor count: 12
Processor speed: 3300 MHz
Built-in memory: 130972 MB
Free memory: 81345 MB
Memory available to Photoshop: 119460 MB
Memory used by Photoshop: 70 %
Surface Dial: Enabled.
Alias Layers: Disabled.
Modifier Palette: Enabled.
Highbeam: Disabled.
Image tile size: 1024K
Image cache levels: 6
Font Preview: Medium
TextComposer: Latin
Display: 1
Display Bounds: top=0, left=0, bottom=2160, right=3840
Display: 2
Display Bounds: top=503, left=3840, bottom=1583, right=5760
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=2
NumCLGPUs=2
NumNativeGPUs=0
I cut it off since it didn't seem you were looking for the entire thing.
As far as when I make an ellipse, I get the spinning dots and have to wait several SECONDS before the ellipse is created. Not sure what's going on.
Can no tell much from what you posted I can tell there may be a problem for you have more than one GUP in your machine. I can not tell it there the same of what device drivers you have installed or the Plug-ins you have installed. I aske tot to post you System Info. You posted a little bit of it only....
JJMack,
I am running two video cards - an Nvidia GTX 1070 (monitor 1) and an Nvidia GTX 970 (Monitor 2). Both use the exact same video drivers, so there is NO driver conflict here and all other software works well on both monitors.
I am not reluctant to post my system info. It's just that its a holiday weekend here and I am not always on my PC. So, I have just now found time to post. Have a little patience, please.
Here is my entire sys info from Photoshop:
Number of Launches: 8
Free memory: 2 MB
Memory available to Photoshop: 119458 MB
Highbeam: Enabled.
TextComposer: Latin
Display: 1
Display: 2
Display Bounds: top=0, left=3840, bottom=1080, right=5760
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=2
NumCLGPUs=2
NumNativeGPUs=0
glgpu[0].GLVersion="4.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=8192
glgpu[0].GLName="NVIDIA GeForce GTX 1070"
glgpu[0].GLVendor="NVIDIA Corporation"
glgpu[0].GLVendorID=4318
glgpu[0].GLDriverVersion="23.21.13.8831"
glgpu[0].GLRectTextureSize=32768
glgpu[0].GLRenderer="GeForce GTX 1070/PCIe/SSE2"
glgpu[0].GLRendererID=7041
glgpu[0].HasGLNPOTSupport=1
glgpu[0].GLDriver="C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_c791f781cd94491f\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_c791f781cd94491f\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_c791f781cd94491f\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_c791f781cd94491f\nvldumdx.dll"
glgpu[0].GLDriverDate="20171114000000.000000-000"
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.60 NVIDIA"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[65536]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[0].CLPlatformVersion="1.2"
clgpu[0].CLDeviceVersion="1.2 CUDA"
clgpu[0].IsIntegratedCLGPU=0
clgpu[0].CLMemoryMB=8192
clgpu[0].CLName="GeForce GTX 1070"
clgpu[0].CLVendor="NVIDIA Corporation"
clgpu[0].CLVendorID=4318
clgpu[0].CLDriverVersion="388.31"
clgpu[0].CLBandwidth=1.89517e+11
clgpu[0].CLCompute=2560.74
glgpu[1].GLVersion="4.1"
glgpu[1].IsIntegratedGLGPU=0
glgpu[1].GLMemoryMB=8192
glgpu[1].GLName="NVIDIA GeForce GTX 970"
glgpu[1].GLVendor="NVIDIA Corporation"
glgpu[1].GLVendorID=4318
glgpu[1].GLDriverVersion="23.21.13.8831"
glgpu[1].GLRectTextureSize=32768
glgpu[1].GLRenderer="GeForce GTX 1070/PCIe/SSE2"
glgpu[1].GLRendererID=5058
glgpu[1].HasGLNPOTSupport=1
glgpu[1].GLDriver="C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_c791f781cd94491f\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_c791f781cd94491f\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_c791f781cd94491f\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_c791f781cd94491f\nvldumdx.dll"
glgpu[1].GLDriverDate="20171114000000.000000-000"
glgpu[1].CanCompileProgramGLSL=1
glgpu[1].GLFrameBufferOK=1
glgpu[1].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.60 NVIDIA"
glgpu[1].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[65536]
glgpu[1].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
glgpu[1].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
glgpu[1].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[1].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[1].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[1].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[1].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[1].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
glgpu[1].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[1].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[1].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[1].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[1].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[1].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[1].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[1].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[1].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[1].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[1].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[1].CLPlatformVersion="1.2"
clgpu[1].CLDeviceVersion="1.2 CUDA"
clgpu[1].IsIntegratedCLGPU=0
clgpu[1].CLMemoryMB=4096
clgpu[1].CLName="GeForce GTX 970"
clgpu[1].CLVendor="NVIDIA Corporation"
clgpu[1].CLVendorID=4318
clgpu[1].CLDriverVersion="388.31"
clgpu[1].CLBandwidth=1.44484e+11
clgpu[1].CLCompute=1687.66
License Type: Subscription
Serial number: 96040047657973705965
GUIDBucket:
Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\
Temporary file path: C:\Users\DSILVE~1\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
Startup, 931.0G, 371.4G free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\Plug-Ins\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Plug-Ins\
Installed components:
A3DLIBS.dll A3DLIB Dynamic Link Library 9.2.0.112
ACE.dll ACE 2017/09/19-18:51:44 79.586793 79.586793
AdbePM.dll PatchMatch 2016/11/03:19:48:57 1.578146 1.578146
AdobeLinguistic.dll Adobe Linguisitc Library 10.0.0
AdobeOwl.dll Adobe Owl 5.2.11
AdobePDFL.dll PDFL 2017/09/01-01:08:01 79.239219 79.239219
AdobePIP.dll Adobe Product Improvement Program 7.4.1.60.45263
AdobeSVGAGM.dll AdobeSVGAGM 79.586793 79.586793
AdobeXMP.dll Adobe XMP Core 2017/07/13-01:06:39 79.160924 79.160924
AdobeXMPFiles.dll Adobe XMP Files 2017/07/13-01:06:39 79.160924 79.160924
AdobeXMPScript.dll Adobe XMP Script 2017/07/13-01:06:39 79.160924 79.160924
adobe_caps.dll Adobe CAPS 10,0,0,6
AGM.dll AGM 2017/09/19-18:51:44 79.586793 79.586793
ahclient.dll AdobeHelp Dynamic Link Library 3.0.0.6
AIDE.dll AIDE 2016/05/27-01:08:49 79.574279 79.574279
amtlib.dll AMTLib (64 Bit) 10.0.0.221 BuildVersion: 10.0; BuildDate: Tue Aug 1 2017 8:28:8) 1.000000
ARE.dll ARE 2017/09/19-18:51:44 79.586793 79.586793
AXE8SharedExpat.dll AXE8SharedExpat 2015/03/13-23:40:54 79.562390 79.562390
AXEDOMCore.dll AXEDOMCore 2015/03/13-23:40:54 79.562390 79.562390
Bib.dll BIB 2017/09/19-18:51:44 79.586793 79.586793
BIBUtils.dll BIBUtils 2017/09/19-18:51:44 79.586793 79.586793
boost_date_time.dll photoshopdva 11.1.0
boost_filesystem.dll photoshopdva 11.1.0
boost_signals.dll photoshopdva 11.1.0
boost_system.dll photoshopdva 11.1.0
boost_threads.dll photoshopdva 11.1.0
cg.dll NVIDIA Cg Runtime 3.0.00007
cgGL.dll NVIDIA Cg Runtime 3.0.00007
CITThreading.dll Adobe CITThreading 2.1.0.1 2.1.0.1
CoolType.dll CoolType 2017/09/19-18:51:44 79.586793 79.586793
CRClient.dll Adobe Crash Reporter Client DLL 1.6.1.0
dnssd.dll Bonjour 3,0,0,2
dvaaudiodevice.dll photoshopdva 11.1.0
dvacore.dll photoshopdva 11.1.0
dvacrashhandler.dll Adobe Audition CC 2017 10.0.0
dvamarshal.dll photoshopdva 11.1.0
dvamediatypes.dll photoshopdva 11.1.0
dvametadata.dll photoshopdva 11.1.0
dvametadataapi.dll photoshopdva 11.1.0
dvametadataui.dll photoshopdva 11.1.0
dvaplayer.dll photoshopdva 11.1.0
dvatransport.dll photoshopdva 11.1.0
dvaui.dll photoshopdva 11.1.0
dvaunittesting.dll photoshopdva 11.1.0
dynamiclink.dll photoshopdva 11.1.0
ExtendScript.dll ExtendScript 2017/08/31-12:13:14 81.1133690 81.1133690
icucnv40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icudt40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icuuc40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
igestep30.dll IGES Reader 9.3.0.113
imslib.dll IMSLib DLL 10.0.0.22
JP2KLib.dll JP2KLib 2017/08/23-01:11:25 79.267771 79.267771
libifcoremd.dll Intel(r) Visual Fortran Compiler 10.0 (Update A)
libiomp5md.dll Intel(R) OpenMP* Runtime Library 5.0
libmmd.dll Intel(R) C/C++/Fortran Compiler 17.0.0
LogSession.dll LogSession 7.4.1.60.45263
mediacoreif.dll photoshopdva 11.1.0
MPS.dll MPS 2017/09/01-01:08:01 79.586120 79.586120
pdfsettings.dll Adobe PDFSettings 1.04
Photoshop.dll Adobe Photoshop CC 2018 19.0
Plugin.dll Adobe Photoshop CC 2018 19.0
PlugPlugExternalObject.dll Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit) 8.0.0
PlugPlugOwl.dll Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit) 8.0.0.55
PSArt.dll Adobe Photoshop CC 2018 19.0
PSCloud.dll 1.0.0.1
PSViews.dll Adobe Photoshop CC 2018 19.0
SCCore.dll ScCore 2017/08/31-12:13:14 81.1133690 81.1133690
SVGRE.dll SVGRE 79.586793 79.586793
svml_dispmd.dll Intel(R) C/C++/Fortran Compiler 17.0.0
tbb.dll Intel(R) Threading Building Blocks for Windows 2017, 0, 2017, 0118
tbbmalloc.dll Intel(R) Threading Building Blocks for Windows 2017, 0, 2017, 0118
TfFontMgr.dll FontMgr 9.3.0.113
TfKernel.dll Kernel 9.3.0.113
TFKGEOM.dll Kernel Geom 9.3.0.113
TFUGEOM.dll Adobe, UGeom© 9.3.0.113
updaternotifications.dll Adobe Updater Notifications Library 10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME) 10.0.0.1
VulcanControl.dll Vulcan Application Control Library 5.3.0.16
VulcanMessage5.dll Vulcan Message Library 5.3.0.16
WRServices.dll WRServices Thu Jan 07 2016 04:50:10 Build 0.21960 0.21960
wu3d.dll U3D Writer 9.3.0.113
Required plug-ins:
3D Studio 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
Accented Edges 19.0 - from the file “Filter Gallery.8bf”
Adaptive Wide Angle 19.0 - from the file “Adaptive Wide Angle.8bf”
Angled Strokes 19.0 - from the file “Filter Gallery.8bf”
Average 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “Average.8bf”
Bas Relief 19.0 - from the file “Filter Gallery.8bf”
BMP 19.0 - from the file “Standard MultiPlugin.8bf”
Camera Raw 10.0 - from the file “Camera Raw.8bi”
Camera Raw Filter 10.0 - from the file “Camera Raw.8bi”
Chalk && Charcoal 19.0 - from the file “Filter Gallery.8bf”
Chrome 19.0 - from the file “Filter Gallery.8bf”
Cineon 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “Cineon.8bi”
Clouds 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “Clouds.8bf”
Collada 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
Color Halftone 19.0 - from the file “Standard MultiPlugin.8bf”
Colored Pencil 19.0 - from the file “Filter Gallery.8bf”
CompuServe GIF 19.0 - from the file “Standard MultiPlugin.8bf”
Conté Crayon 19.0 - from the file “Filter Gallery.8bf”
Craquelure 19.0 - from the file “Filter Gallery.8bf”
Crop and Straighten Photos 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “CropPhotosAuto.8li”
Crop and Straighten Photos Filter 19.0 - from the file “Standard MultiPlugin.8bf”
Crosshatch 19.0 - from the file “Filter Gallery.8bf”
Crystallize 19.0 - from the file “Standard MultiPlugin.8bf”
Cutout 19.0 - from the file “Filter Gallery.8bf”
Dark Strokes 19.0 - from the file “Filter Gallery.8bf”
De-Interlace 19.0 - from the file “Standard MultiPlugin.8bf”
Dicom 19.0 - from the file “Dicom.8bi”
Difference Clouds 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “Clouds.8bf”
Diffuse Glow 19.0 - from the file “Filter Gallery.8bf”
Displace 19.0 - from the file “Standard MultiPlugin.8bf”
Dry Brush 19.0 - from the file “Filter Gallery.8bf”
Eazel Acquire 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “EazelAcquire.8ba”
Entropy 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “statistics.8ba”
Export Color Lookup Tables 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “Export3DLUT.8be”
Extrude 19.0 - from the file “Standard MultiPlugin.8bf”
FastCore Routines 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “FastCore.8bx”
Fibers 19.0 - from the file “Standard MultiPlugin.8bf”
Film Grain 19.0 - from the file “Filter Gallery.8bf”
Filter Gallery 19.0 - from the file “Filter Gallery.8bf”
Flash 3D 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
Fresco 19.0 - from the file “Filter Gallery.8bf”
Glass 19.0 - from the file “Filter Gallery.8bf”
Glowing Edges 19.0 - from the file “Filter Gallery.8bf”
Google Earth 4 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
Graphic Pen 19.0 - from the file “Filter Gallery.8bf”
Halftone Pattern 19.0 - from the file “Filter Gallery.8bf”
Halide Bottlenecks 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “HalideBottlenecks.8bx”
HDRMergeUI 19.0 - from the file “HDRMergeUI.8bf”
HSB/HSL 19.0 - from the file “Standard MultiPlugin.8bf”
IFF Format 19.0 - from the file “Standard MultiPlugin.8bf”
IGES 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
Ink Outlines 19.0 - from the file “Filter Gallery.8bf”
JPEG 2000 19.0 - from the file “JPEG2000.8bi”
Kurtosis 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “statistics.8ba”
Lens Blur 19.0 - from the file “Lens Blur.8bf”
Lens Correction 19.0 - from the file “Lens Correction.8bf”
Lens Flare 19.0 - from the file “Standard MultiPlugin.8bf”
Liquify 19.0 - from the file “Liquify.8bf”
Matlab Operation 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “ChannelPort.8bf”
Maximum 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “statistics.8ba”
Mean 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “statistics.8ba”
Measurement Core 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “MeasurementCore.8me”
Median 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “statistics.8ba”
Mezzotint 19.0 - from the file “Standard MultiPlugin.8bf”
Minimum 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “statistics.8ba”
MMXCore Routines 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “MMXCore.8bx”
Mosaic Tiles 19.0 - from the file “Filter Gallery.8bf”
Multiprocessor Support 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “MultiProcessor Support.8bx”
Neon Glow 19.0 - from the file “Filter Gallery.8bf”
Note Paper 19.0 - from the file “Filter Gallery.8bf”
NTSC Colors 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “NTSC Colors.8bf”
Ocean Ripple 19.0 - from the file “Filter Gallery.8bf”
OpenEXR 19.0 - from the file “Standard MultiPlugin.8bf”
Paint Daubs 19.0 - from the file “Filter Gallery.8bf”
Palette Knife 19.0 - from the file “Filter Gallery.8bf”
ParticleShop NO VERSION - from the file “particleshop.8bf”
Patchwork 19.0 - from the file “Filter Gallery.8bf”
Paths to Illustrator 19.0 - from the file “Standard MultiPlugin.8bf”
PCX 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “PCX.8bi”
Photocopy 19.0 - from the file “Filter Gallery.8bf”
Photoshop 3D Engine 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “Photoshop3DEngine.8bi”
Photoshop Touch 19.0 - from the file “PSDX.8bi”
Picture Package Filter 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “ChannelPort.8bf”
Pinch 19.0 - from the file “Standard MultiPlugin.8bf”
Pixar 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “Pixar.8bi”
Plaster 19.0 - from the file “Filter Gallery.8bf”
Plastic Wrap 19.0 - from the file “Filter Gallery.8bf”
PLY 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
Pointillize 19.0 - from the file “Standard MultiPlugin.8bf”
Polar Coordinates 19.0 - from the file “Standard MultiPlugin.8bf”
Portable Bit Map 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “PBM.8bi”
Poster Edges 19.0 - from the file “Filter Gallery.8bf”
PRC 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
Radial Blur 19.0 - from the file “Standard MultiPlugin.8bf”
Radiance 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “Radiance.8bi”
Range 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “statistics.8ba”
Render Color Lookup Grid 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “Export3DLUT.8be”
Reticulation 19.0 - from the file “Filter Gallery.8bf”
Ripple 19.0 - from the file “Standard MultiPlugin.8bf”
Rough Pastels 19.0 - from the file “Filter Gallery.8bf”
Save for Web 19.0 - from the file “Save for Web.8be”
ScriptingSupport 19.0 - from the file “ScriptingSupport.8li”
Shake Reduction 19.0 - from the file “Shake Reduction.8bf”
Shear 19.0 - from the file “Standard MultiPlugin.8bf”
Skewness 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “statistics.8ba”
Smart Blur 19.0 - from the file “Standard MultiPlugin.8bf”
Smudge Stick 19.0 - from the file “Filter Gallery.8bf”
Solarize 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “Solarize.8bf”
Spaces 19.0 - from the file “Spaces.8li”
Spatter 19.0 - from the file “Filter Gallery.8bf”
Spherize 19.0 - from the file “Standard MultiPlugin.8bf”
Sponge 19.0 - from the file “Filter Gallery.8bf”
Sprayed Strokes 19.0 - from the file “Filter Gallery.8bf”
Stained Glass 19.0 - from the file “Filter Gallery.8bf”
Stamp 19.0 - from the file “Filter Gallery.8bf”
Standard Deviation 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “statistics.8ba”
STL 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
Sumi-e 19.0 - from the file “Filter Gallery.8bf”
Summation 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “statistics.8ba”
Targa 19.0 - from the file “Standard MultiPlugin.8bf”
Texturizer 19.0 - from the file “Filter Gallery.8bf”
Tiles 19.0 - from the file “Standard MultiPlugin.8bf”
Torn Edges 19.0 - from the file “Filter Gallery.8bf”
Twirl 19.0 - from the file “Standard MultiPlugin.8bf”
U3D 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
Underpainting 19.0 - from the file “Filter Gallery.8bf”
Vanishing Point 19.0 - from the file “VanishingPoint.8bf”
Variance 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “statistics.8ba”
Virtual Reality Modeling Language | VRML 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
Water Paper 19.0 - from the file “Filter Gallery.8bf”
Watercolor 19.0 - from the file “Filter Gallery.8bf”
Wave 19.0 - from the file “Standard MultiPlugin.8bf”
Wavefront|OBJ 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
WIA Support 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “WIASupport.8li”
Wind 19.0 - from the file “Standard MultiPlugin.8bf”
Wireless Bitmap 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “WBMP.8bi”
ZigZag 19.0 - from the file “Standard MultiPlugin.8bf”
Optional and third party plug-ins: NONE
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load: NONE
Extensions:
com.adobe.inapp.purchase 2.11.27 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\purchase.html”
Libraries 2.11.27 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\index.html”
Start 2.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.ccx.start\index.html”
Export As 3.0.13 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
Flame Painter Connect 1.2.0 - from the file “C:\Users\D Silverman\AppData\Roaming\Adobe\CEP\extensions\com.escapemotions.flamepainterconnect\index.html”
MagicSquire 1.0.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\MagicSquireCC2014\index.html”
ParticleShop 1.0.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.corel.particleshoppanel\index.html”
com.adobe.Butler.backend 2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.Butler.backend\index.html”
New Document 2.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.ccx.fnft\fnft.html”
Adobe Color Themes 6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
Brusherator Preview 1.0.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.kritskiy.previewrator\index.html”
Brusherator 1.2.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.kritskiy.brusherator\index.html”
MagicPicker 5.2.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\MagicPickerCC2014\index.html”
Brusherator Plus 1.2.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.kritskiy.bt_a\index.html”
Installed TWAIN devices: NONE
https://forums.adobe.com/people/Sci-Fi+Photo+Guy wrote
JJMack,
Your post seems to state you are having long delays. I have two Workstations with CC 2018 one has three displays anf the other two displays. They are not not having your problem both run Windows 10. The big difference I see is my Workstation have one Nvidia display adapters. One has a Quadro 4000 and the other a Quadro K2200.
The K2200 drives three displays two are 4:3 1600x1200 displays where the middle display is a 16:9 3840x2160 display. Here is its screen capture and system info. My other workstation loads some additional third party plug-]ins so compare this systems CC 2018 System Info to yours see if you see any other big differences beside displays adapters.... You seem also to have loaded many extensions perhaps try removing them. See if one of these is causing your issues
Adobe Photoshop Version: 19.0 20170929.r.165 2017/09/29: 1138933 x64
Number of Launches: 5
System architecture: Intel CPU Family:6, Model:14, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
Physical processor count: 4
Logical processor count: 8
Processor speed: 3600 MHz
Built-in memory: 32698 MB
Free memory: 18447 MB
Memory available to Photoshop: 29370 MB
Highbeam: Disabled.
Image cache levels: 4
TextComposer: Latin
Display: 1
Display Bounds: top=0, left=0, bottom=1200, right=1600
Display: 2
Display Bounds: top=0, left=5440, bottom=1200, right=7040
Display: 3
Display Bounds: top=0, left=1600, bottom=2160, right=5440
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumNativeGPUs=0
glgpu[0].GLMemoryMB=4096
glgpu[0].GLName="NVIDIA Quadro K2200"
glgpu[0].GLDriverVersion="10.18.13.5413"
glgpu[0].GLRectTextureSize=16384
glgpu[0].GLRenderer="Quadro K2200/PCIe/SSE2"
glgpu[0].GLRendererID=5050
glgpu[0].GLDriver="nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvwgf2umx.dll"
glgpu[0].GLDriverDate="20150910000000.000000-000"
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.50 NVIDIA"
Serial number: 96040654751133263149
GUIDBucket:
Temporary file path: C:\Users\jjmac\AppData\Local\Temp\
Scratch volume(s):
Startup, 466.5G, 336.9G free
PSCloud.dll 1.0.0.1
Required plug-ins:
3D Studio 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
Average 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Average.8bf”
Cineon 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Cineon.8bi”
Clouds 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Clouds.8bf”
Collada 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
Crop and Straighten Photos 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “CropPhotosAuto.8li”
Difference Clouds 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Clouds.8bf”
Eazel Acquire 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “EazelAcquire.8ba”
Entropy 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
Export Color Lookup Tables 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Export3DLUT.8be”
FastCore Routines 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “FastCore.8bx”
Flash 3D 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
Google Earth 4 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
Halide Bottlenecks 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “HalideBottlenecks.8bx”
IGES 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
Kurtosis 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
Matlab Operation 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “ChannelPort.8bf”
Maximum 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
Mean 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
Measurement Core 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “MeasurementCore.8me”
Median 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
Minimum 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
MMXCore Routines 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “MMXCore.8bx”
Multiprocessor Support 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “MultiProcessor Support.8bx”
NTSC Colors 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “NTSC Colors.8bf”
PCX 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “PCX.8bi”
Photoshop 3D Engine 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Photoshop3DEngine.8bi”
Picture Package Filter 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “ChannelPort.8bf”
Pixar 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Pixar.8bi”
PLY 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
Portable Bit Map 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “PBM.8bi”
PRC 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
Radiance 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Radiance.8bi”
Range 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
Render Color Lookup Grid 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Export3DLUT.8be”
Skewness 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
Solarize 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Solarize.8bf”
Standard Deviation 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
STL 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
Summation 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
U3D 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
Variance 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
Virtual Reality Modeling Language | VRML 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
Wavefront|OBJ 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
WIA Support 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “WIASupport.8li”
Wireless Bitmap 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “WBMP.8bi”
Extensions:
com.adobe.inapp.purchase 2.11.27 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_11_27\purchase.html”
Libraries 2.11.27 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_11_27\index.html”
Adobe Color Themes 6.1.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\KulerPanelHTMLBundle\index.html”
Yeah exactly the same problem I also had. Can anyone know how to fix please.?
Can you post your Photoshop System Info he does not seem willing to do that. The Part he did post show he may have a configuration problem. He may have dissimular GPUs in his machine that can cause Photoshop problems.
I am now tryna use a rectangular shape tool(U)with a path option from(option bar). Then there is no lagging or any delay.
But when I transform that path into shape. It is start lagging and showing loading icon. I hope photoshop fixed that issues very soon.
And I am sure this problem is not very related to GPU or tweaking a preferences.
Thanks for the response btw.
You never posted your PS System INFO...
