Hi!
Is there a shortcut key to rename layers?
There isn't a default shortcut for Layer > Rename Layer but you can add one via Edit > Keyboard Shortcuts > Shortcuts for Application Menus > Layer > Rename Layer.
Note that many key combinations are already assigned elsewhere, so you many have to hunt to find a unused combo, or you can simply remap the keys to this shortcut. Once you add it, the shortcut will be listed to the right of the command in the Layers menu.
I'm not aware of one, you double click on the text in the Layer in the Layer Panel to rename it.
thanks.I am aware of this method,But I'm looking for a shortcut key on the keyboard
Thanks a lot.
You are welcome!
