Is there a way to completely isolate the mouth movement, using only the information gained by the "audio input"?
Nov 27, 2017 Nov 27, 2017
I've completed the mouth sync using "compute lip sync from scene audio". No more mouth animation needed, and have therefore deselected the "lip sync" function on the puppet properties panel.
But the mouth continues to pick up information (it moves) when the "Face" camera input is selected.
Any help appreciated! Thanks, Ed
435
Guru , Nov 27, 2017 Nov 27, 2017
Okay, here is the designed workaround straight from the Ch team.
Remove the smile and surprise tags from those mouth shapes, and there will only be the neutral mouth except when there is audio to record. So after those tags are removed, the face and lip sync behaviors can both be enabled. Just put the audio into the timeline, turn on both the camera and mic, and record.
Guru ,
Is the mic turned off, and the mouth strength set to zero?
thanks for the reply
Yes. Mic off, and the mouth strength set to zero but still the mouth shapes are triggered.
Guru ,
So, after playing around with this a little, here's what I found.
Even with lip sync disabled the mouth still responds to the camera, such as surprised, or smile, and it will record those mouth movements. But, if the audio lip sync has already been recorded, either directly or using the timeline compute function, then the video mouth movements do not appear during that previously recorded audio lip sync duration in the timeline.
Seems strange to me, and I don't see a way around it except to edit the unwanted mouth actions out of the timeline.
Guru ,
Here is an example of what I was trying to describe. The first is recorded from video with the mic and lip sync off, and mouth strength set to zero. No audio. The surprise is showing. The second has audio recorded with lip sync on. The surprise mouth is not showing where the audio is. It seems to make no difference in which order the audio is added.
Thank you for the reply
The "surprise" mouth shape doesn't seem to appear as an editable element on the mouth timeline. So unless there is a letter shape on the timeline then the "surprised" mouth shape will be triggered by the camera, regardless of lip sync being on or off. Tricky trying to explain this on text!
I solved it by replacing the surprised mouth shape with the default. It is a cheat and not a proper solution, as I lose the "surprised" mouth from my options.
Guru ,
Nov 28, 2017 Nov 28, 2017
ok awesome. thanks KJerryK... and the magical Adobe CH support team in the sky!
