hi,everyone!thanks help first!
the question:
I created two files with the animate cc 2018 published as HTML 5 canvas. But why these two files is the same id? After I am making a file, copied to copy, change the content into the second file.
This id is generated according to what?
thank you!!
what are you calling an 'ID'?
HI,kglad
like this:
lib.properties = {
width: 1,
height: 1,
fps: 12,
color: "#FFFFFF",
opacity: 1.00,
manifest: [],
preloads: []
the id is '9CDCF89115C51741845FD719570D0412'.
i don't know (or, at least, i don't remember) how that id is generated.
someone else asked a question about it recently and i answered that question but i don't remember the question or the answer.
Can you provide us with a reference URL here of the post that you are talking about so that we have more context?
Preran
Hi Preran,
Through the template I create two different files. And JS export file Lib attribute ID is the same.
How to avoid it?
Or the name of the ID to generate what are the rules?
thank you!
Hi.
I also don't really get how this value is generated, but you can change it manually to whatever you want to as long as you use the same value in the .html and in the .js (twice in the JS).
Thanks for your reply. But I have a lot of documents, if you have any modify files that is about to change again, so a lot of work.
I want to know, too.
I also want to know.
Can I set the ID in ANCC?
ID found in ANNCC.
