3 Replies Latest reply on Apr 29, 2016 3:18 AM by taras.h
    Warp stablizer help - LOCKED
    dr.Jacobe Level 1
      When I use the Warp Stabilizer it says, "To avoid extreme cropping set framing to stabilize only or adjust other perimeters." How do I do that?
      [Title edited by moderator to make it more useful. Also, thread locked because after four years, this thread has been resurrected just to insult and that's not cool - MOD]
        • 1. Re: help
          Dave LaRonde Level 6
          You go to AE's online help, you put in the search term warp stabilizer and find the fine training materials that are available.
          Any questions?
          EDIT [personal content removed by moderator]
          • 2. Re: help
            A.I.1 Level 3
            There's too much motion in the clip for the stabilization options you are using, which would result in a lot of cropping.  If you have stabilization result set to "No motion" you could set it to smooth motion instead.
            ""To avoid extreme cropping set framing to stabilize only or adjust other perimeters." How do I do that?"
            To set framing to "stabilization only", in the effects tab of your clip, under the "Warp Stabilizor" effect, open "Borders", next to "Framing" change it's setting to "Stabilize only"
            • 3. Re: help
              taras.h Level 1
              with answers like that, do us all a favour and crawl back into your hole and don't re-emerge for another 100 years
