11 Replies Latest reply on May 14, 2012 10:37 PM by Sudeshnasarkar27
    Crash in Flash Pro CS6
    IanD Level 1
      Hi folks,
      I have a minute of video that I am trying to import as a PNG image sequence.  Crash.  Crash.  Crash.  If anyone has time to test ...
      Alright .. 5 minutes later .. import sequence to stage OK .. Save OK .. Now this is what happens when publish to HTML via Toolkit for JS.  Parent FLA now crashing Flash on launch.
      __________________
      Few hours later ..
      The FLA is 89MB and there are 1400 JPEG images, average size about 40KB.  After re-jigging the PNG sequence to JPG, I added a soundtrack got it to import the sequence and save. So far so good.  Export via Toolkit for JS.  Works fine in browser.  Close FLA.  Re-open FLA and crash.
      Crash report reads at last line: Physical Memory: Page Size = 4k, Total = 12288M, Free = 17592186042454M
      WTF!!  Couldn't be a memory leak could it?  NB I have 12GB RAM on board.
      Process:         Adobe Flash CS6 [989]
      Path:            /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/MacOS/Adobe Flash CS6
      Identifier:      com.adobe.flash
      Version:         12.0.0.481 (12.0.0)
      Code Type:       X86 (Native)
      Parent Process:  launchd [670]
      Date/Time:       2012-05-08 16:33:44.914 +1000
      OS Version:      Mac OS X Server 10.7.3 (11D50b)
      Report Version:  9
      Interval Since Last Report:          608662 sec
      Crashes Since Last Report:           63
      Per-App Interval Since Last Report:  47370 sec
      Per-App Crashes Since Last Report:   12
      Anonymous UUID:                      1B23604B-403A-4AF9-8D67-FCDCD9535F80
      Crashed Thread:  0  Dispatch queue: com.apple.main-thread
      Exception Type:  EXC_BAD_ACCESS (SIGBUS)
      Exception Codes: KERN_PROTECTION_FAILURE at 0x000000000057ab88
      VM Regions Near 0x57ab88:
          __PAGEZERO             0000000000000000-0000000000001000 [    4K] ---/--- SM=NUL  /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/MacOS/Adobe Flash CS6
      --> __TEXT                 0000000000001000-0000000001b82000 [ 27.5M] r-x/rwx SM=COW  /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/MacOS/Adobe Flash CS6
          __DATA                 0000000001b82000-0000000001cda000 [ 1376K] rw-/rwx SM=COW  /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/MacOS/Adobe Flash CS6
      Application Specific Information:
      objc[989]: garbage collection is OFF
      Java information:
      Exception type: Bus Error (0xa) at pc=0000000099184c52
      Java VM: Java HotSpot(TM) Client VM (20.6-b01-415 mixed mode macosx-x86)
      Current thread (0000000029bdcc00):  JavaThread "main" [_thread_in_native, id=-1395912000, stack(00000000bf800000,00000000c0000000)]
      Stack: [00000000bf800000,00000000c0000000]
      Java Threads: ( => current thread )
        0000000062be0400 JavaThread "Thread-4" [_thread_blocked, id=-1156677632, stack(00000000bafe8000,00000000bb0e8000)]
        0000000062bdfc00 JavaThread "RegisterThread" [_thread_in_Java, id=-1165164544, stack(00000000ba7d0000,00000000ba8d0000)]
        0000000029413400 JavaThread "Code Model Worker" daemon [_thread_blocked, id=-1313964032, stack(00000000b19e8000,00000000b1ae8000)]
        0000000029412800 JavaThread "Code Model Worker" daemon [_thread_blocked, id=-1315020800, stack(00000000b18e6000,00000000b19e6000)]
        0000000063429000 JavaThread "FelixPackageAdmin" daemon [_thread_blocked, id=-1316077568, stack(00000000b17e4000,00000000b18e4000)]
        0000000063428800 JavaThread "FelixStartLevel" daemon [_thread_blocked, id=-1317134336, stack(00000000b16e2000,00000000b17e2000)]
        0000000029d7e000 JavaThread "FelixDispatchQueue" [_thread_blocked, id=-1318191104, stack(00000000b15e0000,00000000b16e0000)]
        00000000293ea000 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=-1320304640, stack(00000000b13dc000,00000000b14dc000)]
        00000000293e9000 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=-1321361408, stack(00000000b12da000,00000000b13da000)]
        00000000293e8000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=-1322418176, stack(00000000b11d8000,00000000b12d8000)]
        00000000293e7000 JavaThread "Surrogate Locker Thread (Concurrent GC)" daemon [_thread_blocked, id=-1323474944, stack(00000000b10d6000,00000000b11d6000)]
        0000000029ce9000 JavaThread "Finalizer" daemon [_thread_blocked, id=-1324531712, stack(00000000b0fd4000,00000000b10d4000)]
        0000000029ce8000 JavaThread "Reference Handler" daemon [_thread_blocked, id=-1325588480, stack(00000000b0ed2000,00000000b0fd2000)]
      =>0000000029bdcc00 JavaThread "main" [_thread_in_native, id=-1395912000, stack(00000000bf800000,00000000c0000000)]
      Other Threads:
        0000000029ce5800 VMThread [stack: 00000000b0dd0000,00000000b0ed0000] [id=-1326645248]
        00000000293ddc00 WatcherThread [stack: 00000000b14de000,00000000b15de000] [id=-1319247872]
      VM state:not at safepoint (normal execution)
      VM Mutex/Monitor currently owned by a thread: None
      Heap
      par new generation   total 14784K, used 12120K [0000000056010000, 0000000057010000, 0000000057010000)
        eden space 13184K,  79% used [0000000056010000, 0000000056a562d8, 0000000056cf0000)
        from space 1600K, 100% used [0000000056cf0000, 0000000056e80000, 0000000056e80000)
        to   space 1600K,   0% used [0000000056e80000, 0000000056e80000, 0000000057010000)
      concurrent mark-sweep generation total 49152K, used 9980K [0000000057010000, 000000005a010000, 000000005e010000)
      concurrent-mark-sweep perm gen total 12288K, used 8253K [000000005e010000, 000000005ec10000, 0000000062010000)
      Code Cache  [0000000054001000, 0000000054132000, 0000000056001000)
      total_blobs=659 nmethods=529 adapters=73 free_code_cache=32312000 largest_free_block=384
      Virtual Machine Arguments:
      JVM Args: -Djava.awt.headless=true -Xmx128m
      Java Command: <unknown>
      Launcher Type: generic
