3 Replies Latest reply on May 9, 2012 6:10 AM by Formzet - Zoetermeer
    Date validation
    Formzet - Zoetermeer Level 1
      I had to cut a date field into 3 pieses ( [day] [month] [year] )
      Now i have to validate the date, but i don't know how.
      I create a script to combine the field values into a new hidden field to perform te validation.
      event.value = vDay.value + "-" + vMonth.value + "-20" + vYear.value;
      It works, but i get a standard error message.
      I want to perfom a custom validation with an custom error message and to reset the fields when input is wrong.
      Can anyone help me with this script?
      I don't know how to perform date validations in Acrobat/Javascript
        • 1. Re: Date validation
          Do you just mean that you want to check if the input is a valid date or
          not? The best way to do that is to try to convert it to a Date object,
          using util.scand(). If the result is null, then it was not a valid date
          string. For example (I'm assuming here that vDay, vMonth and vYear are
          variables pointing to field objects):
          var dateString = vDay.value + "-" + vMonth.value + "-20" + vYear.value;
          var dateObject = util.scand("dd-mm-yyyy", dateString);
          if (dateObject==null) {
          app.alert("Error! This is not a valid date.");
          • 2. Re: Date validation
            What is the "standard" error you are getting?
            Have you tried to use the JavaScript console in Acrobat to see the values you are trying to process?
            Is the month value the 3 character string or a number?
            Are you subtract the number 20 or concatenate the text character string "-20"?
            You could add the following script to a button and then press the button to see what happens as you  enter data into your fields:
            console.show();
            console.clear();
            var vDay = this.getField("vDay");
            var vMonth = this.getField("vMonth");
            var vYear = this.getField("vYear");
            console.println("vDay: " + vDay.value);
            console.println("vMonth: " + vMonth.value);
            console.println("vYear: " + vYear.value);
            var dateString = vDay.value + "-" + vMonth.value + vYear.value;
            console.println("dateString: " + dateString)
            console.println("dateObject: " + dateObject);
            Once you see what is happening with just the fields you can work on building up a more complex script.
            • 3. Re: Date validation
              @try67
              Works perfect.
              Just what i'm looking for
              Thank you
