0 Replies Latest reply on May 8, 2012 7:57 AM by TᴀW
    Smart Guides are buggy CS4
    TᴀW Adobe Community Professional & MVP
      Smart-guides are slightly buggy in CS4 and it makes it a little
      irritating to work with them. I wonder if this is the same in later
      versions.
      For example, try this:
      Create a new document.
      Switch off all snapping (to document grid, guides, baseline etc.). Just
      enable smart guides. And in smart guides, only enable "Align to object
      edges" and "Smart dimensions."
      Now, in the new document, draw a rectangle. Now duplicate it by
      alt-shift-dragging (to constrain direction). Drag it off a few cm to the
      right.
      So we now have two identical rectangles -- both with their top edge
      lying on the same point of the y-axis. Their heights are identical too.
      As so:
      Now, with the black pointer, move the bottom edge of one of the
      rectangles up and down. What happens?
      Sometimes the "identical height" smart guide appears. Sometimes the
      "Align to object edges appears" and sometimes both smart guides appear!
      Why?! Clearly whenver the rectangles are identical height, their bottom
      edges are aligned as well.
      So we should NEVER get a situation where only one or the other of the
      smart guides appears! The smart guides should always either both be on,
      or both be off -- but never one yes and the other no.
      Capice?
      Is this happening is CS6 as well?
      Obviously the situation is much worse when more smart guides are
      allowed, and more snapping to various things is allowed. So when I zoom
      in to look at what has happened, things aren't always aligning perfectly
      despite the guides.
      Ariel
