1. Re: CS6 Master Suite install issue- An incompatible Flash Builder 4.6 has to be unloaded
K VIKAS CHANDRAN Jun 7, 2012 7:17 AM (in response to mikeklar)1.Use the Adobe Creative suites Cleaner tool to remove any trace left of Flash builder
http://www.adobe.com/support/contact/cscleanertool.html
2.Restart machine, Try installing again
Ensure you have complete administrator privileges and right click on the exe and choose "Run as Administrator" while installing, ensure the directory you are writing to has write access for your user.
if it still does not work
3. Uninstall Flash Builder 4.6 using Creative Suites uninstaller
4. Repeat Step 1 and restart machine, download the Standalone installer at
https://www.adobe.com/cfusion/tdrc/index.cfm?product=flash_builder
and install, this should install it, and would take the Serial number from Creative Suites automatically.
Vikas Chandran
Adobe Systems Incorporated
2. Re: CS6 Master Suite install issue- An incompatible Flash Builder 4.6 has to be unloaded
mikeklar Jun 7, 2012 8:22 PM (in response to K VIKAS CHANDRAN)Vikas
I did what you asked, but it didn't work.
Then I uninstalled CS5.5, rebooted and used the "cscleanertool" for CS5, rebooted and started CS6's "setup.exe".
This did allow the installation of Flash Builder 4.6.
However, the process deleted Acrobat and eliminated links to Audition from Premier, as well caused links in Bridge to look for non existing software, i.e. CS5.5 versions. Hence, I "reloaded" Bridge, Premier Pro, Audition and Acrobat. This required upgrading to the most recent releases for more than the re-installed software.
The latter solved the issues of links, but now Acrobat is looking for a serial number to be activated.
Perhaps you may wish to point this out to some of your other colleagues, in that the process is awkward and the fact that Acrobat is now looking for a serial number is disturbing.
Cheers
Michael
3. Re: CS6 Master Suite install issue- An incompatible Flash Builder 4.6 has to be unloaded
K VIKAS CHANDRAN Jun 11, 2012 5:10 AM (in response to mikeklar)Hi Michael,
I have contacted the CS 6 team and have forwarded your concerns regarding the same.
you can expect them to respond with the next steps.
K Vikas Chandran
4. Re: CS6 Master Suite install issue- An incompatible Flash Builder 4.6 has to be unloaded
Mallika Yelandur Jun 12, 2012 1:16 AM (in response to K VIKAS CHANDRAN)I have moved this discussion to the Downloading & Installing forum as the experts on this forum can help you.
-- Mallika Yelandur
Adobe Community Help & Learning
5. Re: CS6 Master Suite install issue- An incompatible Flash Builder 4.6 has to be unloaded
mikeklar Jun 12, 2012 6:19 PM (in response to Mallika Yelandur)Mallika
Thanks, I'll look for it there.
Cheers,
Michael
6. Re: CS6 Master Suite install issue- An incompatible Flash Builder 4.6 has to be unloaded
Manish-Sharma Jun 12, 2012 6:33 PM (in response to mikeklar)Hi ,
We have seen people facing this issue and they have resolved it as well , please find the couple of thread related to this issue as they may help :-
http://forums.adobe.com/message/4138464
http://forums.adobe.com/message/4147060#4147060
My favorite fix :- http://forums.adobe.com/message/4399621#4399621 (renaming the files)
Please try the steps which other people have already tried and it might help you as well, and please revert if you have any query or if problem is not solved.
