2 Replies Latest reply on Aug 5, 2013 3:55 AM by Toon&Beeld
    Premiere CS 6 playback on 2nd Monitor..
    kbirand
      Hi Folks,
      Just uninstalled 5.5 and now I see that none of the sequence settings have playback on second monitor option. Actually Playback Setting
      button is grayed out. Even if I try to create a custom seq.
      Using Mac 10.6.8
      Premiere CS 6
      I have Redrocket card Installed
      and also BMD Declink Studio 2
      Any Ideas ?
      Koray Birand
      www.kroaybirand.co.uk
        • 1. Re: Premiere CS 6 playback on 2nd Monitor..
          petergaraway Adobe Employee
          Hi Koray,
          We've changed where you access 2nd head out and other devices in CS6.
          Try these steps:
          1. From the file menu choose Premiere Pro>Preferences>Playback settings
          You should see your monitors listed under video devices.
          Hope this helps!
          Peter Garaway
          Premiere Pro QE
          • 2. Re: Premiere CS 6 playback on 2nd Monitor..
            Toon&Beeld Level 1
            I use CS6 on a windows PC, triede the same bute no response on the second monitor.
            I use a Quadro 4000: DVi is for the PC the Display export supports a second Acer monitor, and I like to have the edited film paying back also on this acer monitor. I only can do this by dragging the program-window to this monitor.
            Is it an option to find a setting when starting playback the film pays back on the second monitor.
            BTW all the monitors ( 2)  are shown in the playback settings. But no result choosing them.
            thanks
