1. Re: Why is Bridge not listed in the CS6 Extension Manager?
Xiaoyi Tong May 9, 2012 9:04 AM (in response to theMikeD)You can find the answer in FAQ( http://forums.adobe.com/community/creativesuites/extensionmanager/faq ). There is a FAQ link in the Extension Manager user forum page( frame on the right ).
Q: Bridge CS6 was NOT listed in Extension Manager CS6
Mar 18, 2012 10:50 PM
Starting from CS6, Bridge is not supported by Extension Manager anymore. That is why you cannot see it in Extension Manager.
Q: How can I install extensions for Bridge CS6?
Mar 18, 2012 10:43 PM
Because Bridge CS6 is not supported by Extension Manager anymore, you have to install them manually.
For MXP extension, you can convert it to ZXP extensions with Extension Manager CS6. Then try steps below.
For ZXP extension, use utility software such as 7-zip, WinZip or WinRAR to extract it to a folder.If there is no mxi file after extraction, then it is a CSXS extension.
For CSXS ZXP extension, move the folder to following folder.
Windows: "C:\Program Files (x86)\Common Files\Adobe\CS6ServiceManager\extensions\"
Mac: "/Library/Application Support/Adobe/CS6ServiceManager/extensions/"
For non-CSXS ZXP extension, check the content of the MXI file. Copy all source files defined in "..." to the corresponding destination folders manually. If you are not sure where these files should be copied, please paste the mxi file here.
2. Re: Why is Bridge not listed in the CS6 Extension Manager?
theMikeD May 9, 2012 9:07 AM (in response to theMikeD)So it's a feature regression then. Very disappointing.
