2 Replies Latest reply on May 15, 2012 1:07 AM by Madhav Subedi
    passing arguments to a function
    BosDog Level 1
      Hi this is probably something easy someone can help with. I'm calling the below function "FilterFunction" and it works well in this code:
      private function filterTheater():void {
      dataArray.filterFunction = FilterFunction;
      dataArray.refresh() ;
      msc_addItemHandler(event,'filterResourceType','resourceTypeF')
      // rebuild filters
      private function FilterFunction(item:Object):Boolean {
      // theater filter - loops all selected items in theater combo and checks if rows match criteria
      for each (var t:Object in theatreF.selectedItems) {
      if (item.THEATER == t.data && t.assigned) {
      return true ;
      return false ;
      However once I want to add an additional argument for FilterFunction to accept I don't know how to pass in the item:Object as it was already happening before without me needing to specify it in an argument. Once i add another argument I then need to supply 2 arguments. Here is the changed (and problematic) code:
      dataArray.filterFunction = FilterFunction('theater');
      // rebuild filters
      private function FilterFunction(item:Object, filterWhat:String):Boolean {
      return true ;
      return false ;
