2 Replies Latest reply on May 9, 2012 11:31 AM by ax1e2l_b3r4a5s6s
    Applescript - Best way to test for the existence of a text frame
    ax1e2l_b3r4a5s6s Level 1
      I have a text frame I want to perform some operations on if it exists (will in some documents, not in others).
      I can't assume it exists, or a I get errors when it doesn't using the below.  the script works fine if the frames exist.
      repeat with i from (count of listVoucherT) to 1 by -1
                tell application "Adobe InDesign CS5.5"
                          tell the active document
                                    set Text_Frame to the text frame "VOU1"
                                    if (item i of listVoucherC) = "-" then
                                              tell Text_Frame
                                                        set theLines to every line
                                                        move line i to after last word of line (i - 1)
                                              end tell
                                    end if
                                    set Text_Frame to the text frame "VOU2"
                                              tell Text_Frame
                                                        set (item i of listVoucherT) to (" " & (item i of listVoucherT))
                                              end tell
                                    end if
                          end tell
                end tell
      end repeat
      How would one modify this to not throw an error if the frame(s) are not there???
