1 Reply Latest reply on May 30, 2012 4:48 AM by Shripad_joshi
    Can I create other visualization components using OLAPResult from the OLAPQuery on a OLAPCube?
    Shripad_joshi
      I have a OLAPCube/ schema defined. I am executing a OLAPQuery on the Cube. With the result from the query execution, I can create OLAP Data Grid. But I want to know if I can draw any chart from the same result. If yes, then please let me know the way we can do so.
      Thank you...
        • 1. Re: Can I create other visualization components using OLAPResult from the OLAPQuery on a OLAPCube?
          Shripad_joshi Level 1
          /** Date:30-05-2012
                               * function decodes the OLAPResult object into arrayCollection and retruns
                               * the arrayCollection instance...
                              public static function decodeOLAPResult(result:OLAPResult):ArrayCollection
                                        var colAxis:ArrayCollection = result.getAxis(OLAPQuery.COLUMN_AXIS).positions as ArrayCollection;
                                        var columnLength:Number = colAxis.length;
                                        var rowAxis:ArrayCollection = result.getAxis(OLAPQuery.ROW_AXIS).positions as ArrayCollection;
                                        var rowLength:Number = rowAxis.length;
                                        var newChartData:ArrayCollection = new ArrayCollection();
                                        var dataObject:Object;
                                        for(var j:int = 0; j < rowLength; j++)
                                                  var row:OLAPAxisPosition = rowAxis[j];
                                                  var product:String = row.members.toArray().join(",");
                                                  if (product.indexOf("(All)") > -1) continue;
                                                  for (var i:int=0;i<columnLength;i++)
                                                            dataObject = new Object();
                                                            var tuple:OLAPAxisPosition = colAxis[i];
                                                            var period:String = tuple.members.toArray().join(",");
                                                            if (period.indexOf("(All)") > -1) continue;
                                                            for(var rowCount:int=0; rowCount < row.members.length; rowCount++)
        var fieldName:String = String(getFieldName(row.members[rowCount]).toLocaleLowerCase());
        dataObject[fieldName] = row.members[rowCount].name;
                                                            for(var colCount:int=0; colCount < tuple.members.length; colCount++)
        var field:String = String(getFieldName(tuple.members[colCount]).toLocaleLowerCase());
        dataObject[field] = tuple.members[colCount].name;
                                                            dataObject.revenue = result.getCell(j, i).value;
                                                            newChartData.addItem(dataObject);
                                                            //newChartData.push({dim1:dim1, dim2:dim2, dim3:dim3, dim4:dim4, revenue:result.getCell(j, i).value});
                                        return newChartData;
